    I can't connect DWC
    Duet Web Control
    241
    • aego
      aego last edited by
      I can't connect Duet Web Control. I have Duet2 wifi, my firmware is 2.05.01. The connection works via Yat, via Pronterface and Ping is normal. The DWC interface opens normal but is not connected and the connect button does not take effect.
      I need some help
      Thank you
      aego 1 Reply Last reply Reply Quote 0
      • aego
        aego @aego last edited by
        @aego said in I can't connect DWC:
        I need some help
        Thank you
        i am using Chrome
        • HenryDara
          HenryDara last edited by
          Sounds like the IP changed on ya. Use YAT and send M587 (no para) to list net info...
          Is the blue WIFI light on solid? If so, it is connected to your Wifi, and you just need to know the IP address.
          If not these may help...
          To set the network...
          M587 S"SSID" P"password"
          To forget the network
          M588 S"SSID"
          Also
          M552 S0 = Disconnect Wifi
          M552 S1 = Connect Wifi
          • aidar
            aidar last edited by
            Looks to me that network part is ok, as OP says "DWC interface opens normal" .
            Sounds like DWC problem. What version of DWC you have?
            • aego
              aego @HenryDara last edited by
              @HenryDara
              Blue led is on and let see this:
              M552 S1
              ok<LF>WiFi module is connected to access point dlink-3DC4, IP address 192.168.0.55<LF>
              M587
              Remembered networks:<LF>dlink-3DC4 IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0<LF>ok<LF>
              M587 S"DLINK-3DC4" P" 104"
              ok<LF>
              HenryDara 2 Replies Last reply Reply Quote 0
              • HenryDara
                HenryDara @aego last edited by
                @aego try forgetting the network with
                M588 S"dlink-3DC4"
                then adding it back to the list with
                M587 S"dlink-3DC4" P"<wifi password>"
                (replace with your actual password)
                Connect Duet to wifi (if it doesnt automatically)
                M552 S1
                then check it with M587 again
                Not sure why but when mine has gotten hosed up in the past this is how I recovered.
                • HenryDara
                  @aego Also you should be using 192.168.0.55 for your browser address (or 192.168.0.55/reprap.htm to use DWC1)
                  • aego
                    @HenryDara How can I update the DWC in sc card ? The files in the latest version and files in sdcar are diferent
                    Let see what happen
                    M588 S"dlink-3DC4"
                    ok<LF>
                    M587 S"dlink-3DC4" P"103BCfs44"
                    ok<LF>
                    M552 S1
                    ok<LF>
                    m587
                    Remembered networks:<LF>dlink-3DC4 IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0<LF>DLINK-3DC4 IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0<LF>ok<LF>
                    A Former User 1 Reply Last reply Reply Quote 0
                    • A Former User
                      A Former User @aego last edited by
                      put it in your computer and download the DWC release, then extract to /www on SD card.
                      https://github.com/dc42/RepRapFirmware/releases/download/2.05.1/DuetWebControl-SD-2.0.7.zip
                      • aego
                        aego @Guest last edited by
                        @bearer Now everything is ok, after update DWC.
                        Thank you Bearer and HenryDara
