    Help. Duet 0.8.5 not responding
    Firmware installation
    105
    • amcutem
      amcutem last edited by amcutem
      hello, I finally converted my Rostock V2 to a Duet 085. I was able to install to the lates firmware from github and had it almost working, as in I was able to press home and the machined homed. I could also make it move down after homing.
      However, i coudn't level it which I wanted to be able to do before i installed the FSR. I also made the mistake of uploading the other firmware, such as core ay, raddbin, etc.. and after doing this, when i started the machine, it still recognized it as a duet on the web browser. I played with it like that trying to figure out how to get it working completely,
      Being confident that i got that far, I decided to delete everything on the SD CARD so that i could start over and load only the neccesary files. Once i did that, and inserted the SD card back into the duet 085 board, it stopped working and no more blinking. There's a green and red led beside the erase button and a red led stuck on when i plug my micro usb cable. It also seems that it doesn't respond to bossa anymore although it shows on the port and im able to write the Combinefirmware bin. Nothing blinks also. I thought i remembered it blinking.
      Have I bricked my board? MY gf got this for me as a present and it's brand new, except i never installed it. I was afraid this might happen.
      If anyone can help, that would be great. My friend also left his JTAG here and im not sure if that could help. The name is all i know about JTAG.
      sincerely,
      Alex
      • A Former User
        Should only need the micro (mini?) usb cable to recover any firmware related issues afaik even with the first generation Duet boards baring any physical damage.
        If you connect a usb cable, what does the device show up as?
        amcutem 1 Reply Last reply Reply Quote 0
          When you use Bossa to install the firmware, did you remember to check the Erase, Lock and Boot from Flash boxed before you clicked Write? Did it Verify OK?
          It's not normal for any of the LEDs on the Duet 085 to blink.
          amcutem 2 Replies Last reply Reply Quote 0
          • Dougal1957
            Dougal1957 last edited by
            Did you rebuild the SD Card before putting it back in the Duet you say you deleted everything but don't say if you replaced any of the files?
            • amcutem
              ![0_1584100878143_bossa.png](Uploading 100%)
              Thank you for replying.
              That's what i thought also. But after I erased the SD and pasted correct files, it stopped working, and Yat keeps looking for port and then says it's busy. I've tried prontface, but no comm also. I've also uninstalled and installed everything again, but nothing.
              I've attached a screen shot.
              ![alt text](![0_1584100866934_bossa.png](Uploading 100%) image url)![0_1584101035164_WIN_20200313_05_03_28_Pro.jpg](Uploading 100%)
              • amcutem
                amcutem @dc42 last edited by
                @dc42 yes
                • amcutem
                  amcutem @Dougal1957 last edited by
                  @Dougal1957 I did.
                  i pasted:
                  www
                  sys- firmware here
                  macros
                  gcodes
                  Dougal1957 1 Reply Last reply Reply Quote 0
                  • amcutem
                    amcutem @dc42 last edited by amcutem
                    This post is deleted!
                      dc42 administrators @amcutem last edited by dc42
                      @amcutem said in Help. Duet 0.8.5 not responding:
                      That's usually a Windows issue, so you may need to reboot Windows. Make sure you don't have Bossa and YAT loaded at the same time.
                      Unfortunately your screen shot faied to upload. Please try again.
                      • Dougal1957
                        Dougal1957 @amcutem last edited by
                        @amcutem did you also put a config.g file in the SYS Folder?
                        • amcutem
                          @Dougal1957
                          Yes. I've done all that. Anything else?
                          • amcutem
                            amcutem @Guest last edited by
                            @bearer
                            it shoes up as bossa or duet. But i can't communicate with it.
                            A Former User 1 Reply Last reply Reply Quote 0
                            • A Former User
                              A Former User @amcutem last edited by
                              @bearer
                              ? elaborate please, it doesn't make sense to be bossa or duet and not have communication - you need bossa software to communicate with bossa bootloader in the duet to make the board appear like a duet again. does that work?
                              • DocTrucker
                                DocTrucker last edited by
                                Some of the older bossa/duet guides didn't mention explicitly specifying the com port in the command line argument. I needed that when I did it.
                                Alive: 1 Ormerodish machines. 1 Custom Cantilever. 3 P3Steel. 1 Ciclopish scanner. In build: 1 P3Steel. Controllers: 2 Duet 2 , 2 D0.6, 1 D0.8.5, 1 D3 v0.5, 1 RAMPS/DRV8825, 1 Uno/Scan Card.
                                • amcutem
                                  @bearer
                                  Sorry for the mistake.
                                  It actually just shows bossa.
                                  After writting the firmware, COMBINEDFIRMWARE, and shows success, it still shows as bossa and not DUET,then, nothing happens when i connect using YAT. Sometimes it connects, but no response from the board when i type a GCode.
                                  Right now im trying to learn about jtag and if it can help.
                                  Is there a duet repair place i can send it to?
                                  Its a bummer if its shot already cuz its new.
                                  A Former User droftarts 2 Replies Last reply Reply Quote 0
                                  • A Former User
                                    First try the command line version bossac, it'll rule out checking the correct boxes and resetting the board
                                    assuming a normal windows install, with the firmware in your Downloads folder, run in a command prompt:
                                    cd Downloads
                                    "\Program Files (x86)\BOSSA\bossac.exe" -e -w -v -b RepRapFirmware.bin -R
                                    you may have to specify the serial port to use like so:
                                    "\Program Files (x86)\BOSSA\bossac.exe" --PORT=COM5 -e -w -v -b RepRapFirmware.bin -R
                                    if your folders are different, adjust so the paths are correct.
                                    a Duet 085
                                    isn't the 0.8.5 board old? not sure the people who fix acurrent Duet is too familiar with the first generation, but Duet3d themselves may try, however you quickly get to the point where its cheaper to buy a new board.
                                    edit; updated with correct firmware as pr Ians input.
                                    • A Former User
                                      as long as the board shows as bossa it will not respond to gcode, this is the bootloader for the duet and can only be used to flash the firmware.
                                      if you're getting the bootloader odds are you will not need an external programmer.
                                      • droftarts
                                        droftarts Moderator @amcutem last edited by
                                        @amcutem the “combined version” of the firmware is for Duet 2 WiFi and Ethernet. Use the ‘RepRapFirmware.bin’ from 2.05.1 and 1.26.1 release for Duet 06/085.
                                        https://github.com/dc42/RepRapFirmware/releases/tag/2.05.1
