    Solved Maestro Network startup
    Duet Web Control
    102
    • William
      William last edited by William
      Hoping that someone has run across a network startup fix, searched the forum, a lot of can't connect to DWC but no mention of a specific network issue.
      Initial power on will not give me a network connection. Only a quick power cycle will light up the network interface leds on the Maestro and my network switch, then everything works fine.
      It's seems like the network interface does not initialize from a cold startup.
      I'm using a static IP. M98 Pconfig.g gives no errors.
      Any pointers would be appreciated.
      Thanks..
      Firmware Electronics: Duet Maestro 1.0
      Firmware Version: 2.05.1 (2020-02-09b1)
      Web Interface Version: 1.22.6
      ; Configuration file for Duet Maestro (firmware version 2.03)
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Fri Mar 13 2020 15:11:23 GMT-0700 (Pacific Daylight Time)
      M550 P"TEST1" ; set printer name
      M552 P192.168.0.75 S1 ; enable network and set IP address
      M553 P255.255.255.0 ; set netmask
      M554 P192.168.0.26 ; set gateway
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      • A Former User
        need to add M552 S1 to enable the network after setting it up (i think)
        what does it say if you run just M552?
        • William
          @bearer said in Maestro Network startup:
          M552
          I'll give it a try.
          M552
          Network is enabled, configured IP address: 192.168.0.75, actual IP address: 192.168.0.75.
          • A Former User
            Hmm, could be trouble with auto negotiation of the link parameters between the switch and the Maestro, have been a few examples of that. Unless you have a managed switch not much to do about it, but you could try a direct connection to your computer and see if setting a fixed link speed there helps?
              How about if you use DHCP on the duet and let the router reserve the ip address?
              • A Former User
                I don't think its a layer 3 issue, as the lights on the interface would be on even if the IP stuff didn't work.
                • William
                  Splitting out the single line code M552 from;
                  to
                  M552 S1 ; enable network
                  M552 P192.168.0.75 ; set IP address
                  Solved it for for me. Thanks for the pointer bearer!
                  • A Former User
                    Curious does it make a difference if you do M552 S1 P192.168.0.75 instead of M552 P192.168.0.75 S1 ?
                    Are there any other M552 commands in your config? Just asking to see if this is something that should be clearer in the documentation or if it might be unintended behaviour.
                      dc42 administrators @Guest last edited by
                      It shouldn't matter whether you use 1 or 2 separate M552 commands in config.g. The S1 command will be deferred until config.g has completed running.
                      A Former User 1 Reply Last reply Reply Quote 0
                      • A Former User
                        A Former User @dc42 last edited by
                        @dc42 said in Maestro Network startup:
                        so either something else changed or the order mattered even it shouldn't have? which is why I asked as it seemed an improbable explanation.
                        noted, good to know
