    Little bug
    Duet Web Control
    • noisettetbou
      noisettetbou last edited by noisettetbou
      Hi.
      I've found a little bug in the DWC when we use more than 2 tools :
      The text of the name of the heater refers to the bad heater. But the link is OK.
      It's in green (Chauffe X instead of Chauffe U) on the image attached.
      • droftarts
        droftarts administrators @noisettetbou last edited by
        @noisettetbou Yes, this is a known problem with DWC 2.0.7 in some multiple-extruder setups, and has been reported recently eg https://forum.duet3d.com/topic/14743/heater-numbers-incorrect-in-dwc-2-0-7
        I had a message from @chrishamm saying that it should be fixed in the next DWC release.
        • noisettetbou
          OK. Thank you. 👍
          • noisettetbou
            This post is deleted!
