    help on duet 1 wifi!
    Firmware installation
    • vincenzo.serpico
      vincenzo.serpico last edited by
      hi to all,
      sorry if i write in bed position, put i need help! i have a duetwifi 1.0.
      when I bought it I load the 1.18 firmware and work well! for many reasons I turned it off after few week. After years, today connect it and set for a new printer. I upgrade fw but now read different things in settings...before upgrade in settings i see "elettronics: duetwifi 1", now see "duetWiFI 1.02 or later". it's normal??
        Yes that's normal. The Duet wifi 1 was renamed to Duet 2 Wifi to allow more differentiation from the older Duet 0.6 boards.
        There is: Duet 2 Wifi, Duet 2 Ethernet, Duet 2 Maestro, Duet 3 6HC.
        When you updated the firmware, it started using the new name. Nothing else has changed other than what's new and different in the firmware.
