    "Error: Heater 1 not found" issue on Duet Maestro
    Duet Web Control
    • Breadbin
      Breadbin last edited by
      I'm having a problem with setting up a custom printer. I was trying to tune my hotend when I received this message:
      I spent some time looking on this forum and the internet in general but I couldn't find a solution. Here's my config file, if it helps:
      ; Configuration file for Duet Maestro (firmware version 2.03)
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Tue Mar 24 2020 13:00:32 GMT-0700 (Pacific Daylight Time)
      M550 P"Cube Mini"                                  ; set printer name
      M918 P1 E-4 F2000000                               ; configure direct-connect display
      M552 P192.168.1.14 S1                              ; enable network and acquire dynamic address via DHCP
      M569 P0 S0                                         ; physical drive 0 goes backwards
      M569 P1 S1                                         ; physical drive 1 goes forwards
      M569 P2 S1                                         ; physical drive 2 goes forwards
      M569 P3 S1                                         ; physical drive 3 goes forwards
      M569 P4 S0                                         ; physical drive 4 goes backwards
      M584 X0 Y1:4 Z2 E3                                 ; set drive mapping
      M92 X80.00 Y80.00 Z4000.00 E420.00                 ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00                ; set maximum instantaneous speed changes (mm/min)
      M203 X12000.00 Y12000.00 Z180.00 E1200.00          ; set maximum speeds (mm/min)
      M201 X1000.00 Y1000.00 Z20.00 E250.00              ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 I30                       ; set motor currents (mA) and motor idle factor in per cent
      M208 X100 Y100 Z100 S0                             ; set axis maxima
      M574 Z0 S0                                         ; set active low and disabled endstops
      M574 X1 Y2 S3                                      ; set endstops controlled by motor stall detection
      M558 P0 H5 F120 T6000                              ; disable Z probe but set dive height, probe speed and travel speed
      M557 X15:85 Y15:85 S10                             ; define mesh grid
      M307 H0 B0 S1.00                                   ; disable bang-bang mode for the bed heater and set PWM limit
      M305 P0 T100000 B4138 R2200                        ; set thermistor + ADC parameters for heater 0
      M143 H0 S100                                       ; set temperature limit for heater 0 to 120C
      M305 P1 T100000 B4725 C7.060000e-8 R2200           ; set thermistor + ADC parameters for heater 1
      M106 P0 S0 I0 F500 H1 T60                          ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P1 S0.5 I0 F500 H-1                           ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M563 P0 S"Hotend" D0 H1 F0:1                       ; define tool 0
      ; T0                                                 ; select first tool
      What should I do? Any help would be greatly appreciated. Thanks!
      • droftarts
        droftarts administrators @Breadbin last edited by
        @Breadbin Can you go to the G-Code Console tab, send M115 to the Duet, and post the response? This will tell us what firmware version you are using.
        Then send M98 P"config.g" and post any errors it reports.
        • Breadbin
          Thank you for the quick response! After following your instructions I'm thinking that I told the RepRap Configurator Tool the wrong firmware (2.05 when the board is actually running 3).
          Thanks!
          • droftarts
            @Breadbin Yup, that'll do it! And was my suspicion...
            If you saved the json file when you downloaded the configuration last time, you can upload that on the config tool's first page by clicking "Use existing configuration". Then just change the firmware version on the General page, and it should keep all the settings you have already set, and generate a compatible config.g.
            • Breadbin
              Thank you! It looks like it works now.
