Toolboard won't boot?
I have been using my toolboard for a few weeks without issue, but today it has decided to stop booting (I assume).
When I turn it on, the red LED blinks a couple times, and then does a really fast blink 2 or 3 times (too fast to tell), and then turns off. The fan turns off at that point as well (it spins up when it first turns on), but the heater stays on.
I have unplugged everything from the board, made sure there weren't any shorts anywhere, but no luck.I tried doing a factory reset by unplugging the CAN connector, and powering it up while holding both buttons down. It doesn't seem to react at all to doing this - i can see the blinking pattern described above, and then the LED stays dim until I release the two buttons.
Does anyone know what the really fast blinking pattern means? I'm guessing its an error code of some kind, but I don't see any documented error codes anywhere.
Thanks,
Brandon
