    Duet 2 WiFi Firmware upgrade
    Firmware installation
    • Harley3D
      Harley3D last edited by
      Does this Release 3.0 requires no further action when i upload zip file to /sys and /www Directories??
      Below is my current version.
      Firmware Version: 2.03 (2019-06-13b2)
      WiFi Server Version: 1.23
      Web Interface Version: 1.22.6
      Thanks.
      • droftarts
        droftarts administrators @Harley3D last edited by
        @Harley3D Updating to RRF 3 involves quite a bit of action, particularly when moving from versions of RRF2. See https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_Summary_of_what_you_need_to_do_to_convert_your_configuration_and_other_files
        Read from the start of that page to understand the fundamental changes and differences between RRF2 and RRF3.
        • Harley3D
          Totally out of my range!, Think i'll stick to the install i have now. Thanks for the reply!
          • droftarts
            @Harley3D You should be okay updating to 2.05.1, though. Use https://github.com/dc42/RepRapFirmware/releases/tag/2.05.1
            There shouldn't be any changes to your config and other files, though do check the 'what's new' notes to be sure. https://github.com/dc42/RepRapFirmware/blob/dev/WHATS_NEW.md
