    Conditional Gcode question
    Beta Firmware
    • nikscha
      nikscha last edited by
      I want to extrude filament until my filament sensor triggers. I know there is a way where i use the sensor as an endstop, but i would like to know how to do it using conditional gcode. Something like this maybe?:
      while !sensors.filamentsensor.trigger
          G1 E1
      (not sure about the syntax/names)
      As far as i can tell, this wont result in a smooth motion though.
      • OwenD
        OwenD last edited by OwenD
        What's your use case?
        Can't see why it wouldn't process just as fast as any other G Code, but it wouldn't be synchronous with any other moves.
        I don't have a filament monitor, but I presume it will have a triggered state value
        Edit: Just checked and it's "filamentPresent"
        I'd try
        while sensors.filamentMonitors[0].filamentPresent
              G1 E1
              M400 ; wait for move to complete
        This assumes you only have one filament monitor or want to check the first one. (index 0)
        The M400 may be needed to stop a case of many moves being queued before the trigger
        • OwenD
          You could have the problem that filament monitoring is only active when printing from teh SD card
          https://duet3d.dozuki.com/Wiki/Gcode#Section_M591_Configure_filament_sensing
