    Strings parsed for Print Job Stats
    Duet Web Control
    • schneik80undefined
      schneik80
      I was wondering if anyone had the string matching info for the jobs list.
      for example I know the below works:
      ; layerHeigth, 0.30
      ; LayerCount, 50
      ; Filament length: 853mm
      My OCD side would like the formatting to match but my trial and error efforts only resulted in the above working.
      Any chance there are string matches that consistently use spaces and separators?
      I would love if spaces and ":" were recognized.
      ...and while I am at it. Would others find it useful if Jobs list also listed tools used? i.e. 0,1,2,3...
      Thanks.
        schneik80
        I found in modelitems.js
        filament = []
        fileName = null
        firstLayerHeight = 0
        generatedBy = null
        height = 0
        lastModified = null
        layerHeight = 0
        numLayers = 0
        printTime = null
        simulatedTime = null
        size = 0
        this looks like the list of supported stats. still looking for any documentation on what strings will pars and match to these stats?
          The string matching depends on whether you are using Duet 3 + SBC, or any other configuration.
          schneik80undefined 1 Reply Last reply Reply Quote 0
            schneik80 @dc42
            @dc42 Thanks. Currently on:
            Board: Duet WiFi 1.02 or later + DueX5 (duetwifi102)
            Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 2.05.1 (2020-02-09b1)
            Duet WiFi Server Version: 1.23
              dc42 administrators @schneik80
              You will find the string lists in this file https://github.com/dc42/RepRapFirmware/blob/v3.01-dev/src/Storage/FileInfoParser.cpp.
                schneik80
                Excellent! Thank you. This will help me wrap up some requested improvements to a Fusion 360 post to generate gcode
                  schneik80
                  Is "firstLayerHeight" used anywhere in Web control or PanelDue?
