    Unsolved Laser Filament sensor calibration Data
    Filament Monitor
    1
    1
    62
    • X30N
      X30N last edited by
      My filament sensor shows currently in the Calibration Data a minimum of 0%, avg 130% and max 185%.
      Are these valid Data?
      I use one of those Designs that measures movement indirectly over a bearing.
      My previous calibration had a minimum of 10% and max of 180% but "falsely" triggered multiple times a too little movement error and destroyed the print
      ( my pause.g had a retraction of 10mm, but because of a new titanium all metal bridge it should retract around 1mm, my fault)
      Most example calibrations shows an >0% min, so I am reluctant to put the 0% in my config.g
