    Release 3.01-RC8 update
    Firmware installation
    • patelundefined
      patel
      after update printer did not work properly.
      upload all backup file on sys/
      G28
      Warning: Obsolete use of S parameter on G1 command. Use H parameter instead.
      Error: Failed to enable endstops
      4/19/2020, 3:25:34 AM Warning: Obsolete use of S parameter on G1 command. Use H parameter instead.
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.01-RC8 running on Duet WiFi 1.02 or later
      Board ID: 08ODM-9FAP2-LW4SD-6J9D6-3SP6L-12ZZYUsed output buffers: 3 of 24 (17 max)
      Static ram: 28052
      Dynamic ram: 92692 of which 312 recycled
      Exception stack ram used: 352
      Never used ram: 9664
      Tasks: NETWORK(ready,316) HEAT(blocked,1468) MAIN(running,1652) IDLE(ready,80)
      Owned mutexes: WiFi(NETWORK)
      Last reset 00:06:58 ago, cause: power up
      Last software reset details not available
      Error status: 0
      Free file entries: 10
      MCU temperature: min 30.5, current 34.0, max 34.4
      Supply voltage: min 2.0, current 24.2, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
      Date/time: 2020-04-19 03:23:39
      Cache data hit count 746251395
      Slowest loop: 12.40ms; fastest: 0.09ms
      Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
      === MainDDARing ===
      Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
      === AuxDDARing ===
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 206.46ms; fastest: 0.00ms
      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
      HTTP sessions: 1 of 8
      • WiFi -
        Network state is active
        WiFi firmware version 1.23
        WiFi MAC address 454545444
        WiFi Vcc 3.36, reset reason Unknown
        WiFi flash size 4194304, free heap 19056
        WiFi IP address 199.99.99.99
        WiFi signal strength -66dBm, reconnections 0, sleep mode modem
        Socket states: 0 4 0 0 0 0 0 0
        It sounds as though you didn't update your config.g file. https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_Summary_of_what_you_need_to_do_to_convert_your_configuration_and_other_files
        • patelundefined
          patel
          how i can put back old setup. i confuse and lost
            You can upload the previous 2.05.1 bin file and it should detect and install it.
