DueUI Release v3.0.2 Available
https://github.com/gtjoseph/DueUI/releases/tag/v3.0.2
Added UI Test Mode
- There's a new settings option "Test Mode" which, when turned on,
will bypass attempts to connect to a Duet or SBC. This will
allow you to design the GUI without having access to an actual
Duet device. You must still provide a valid URL to the DueUI
config file.
Heater widget updates
Heater state values were updated for RRF 3.01
Fixed incorrect heater tolerance calculations
