    Duet3D not connecting to the computer (Please read carefully)
    Order discussion
    1.8k
    • Reaperrhsundefined
      Reaperrhs
      A few weeks ago i bought a board for printersoloid that I need to return because was defective, this time I buy from filastruder but I take a different approach, I have a brand new laptop, a dedicated PC and my old laptop, I try all kind de cables and troubleshoot everything the same way you guys told me and still have the same problems, at this point is more than clear that is a big quality issue here 2 out 2 from different sellers, I need you guys to authorize a refund from filastruder asap, once again please read carefully and understand I have have tried EVERYTHING.
      Reaperrhsundefined A Former User? 2 Replies Last reply Reply Quote 0
        Reaperrhs @Reaperrhs
        @Reaperrhs This is the old discussion link
        https://forum.duet3d.com/topic/15397/duet3d-not-conecting-to-computer/5
        • A Former User?
          A Former User
          The old thread suggest the board was flashing when you received it, did the new one do the same? At which point did the new stop flashing if so?
            Reaperrhs
            yes, it did just the same, and now the diag LED is bearly light on permanent like the picture on the old post
            gtj0undefined 1 Reply Last reply Reply Quote 0
            • A Former User?
              A Former User
              Thats unfortunate, I'm sure the Duet people would be interested in the timeline from power on and flashing led to dim led; what was connected where etc.
              • gtj0undefined
                gtj0 @Reaperrhs
                @Reaperrhs The faded diag LED can also be caused by something keeping the reset pin grounded.
                Do you have anything connected to the 2-pin header right next to the LED? Is there anything interfering with the reset pushbutton? Is there anything on the underside of the board that could be shorting the pins or button?
                  Reaperrhs
                  on the link posted before is a picture of the board, that shows the pins and the led, but reset pin looks clear
                    Sorry to see you're still having issues.
                    Just to verify, since you did not reply to your previous thread, you have received a new Duet 3 and are having the same issue?
                    You'll recall my comment from the previous thread:
                    Also please note that if the issue with the usb connection was not a problem with the Duet 3 itself you will likely run into the same issue again. This is why we try to eliminate all other factors before approving a warranty replacement.
                    So at this point we really must identify exactly what you have tried so that we can eliminate your setup as the source of the issue.
                    So please provide some details.
                      Reaperrhs
                      i buy another one from a different seller because they were out stock
                        Reaperrhs
                        honestly, i don't understand what do you want me to describe, I follow step by step according to duet, i install all the drivers and programs to get it connected, nothing happens, i place the jumper and erased and still not working, i try 3 different computers and several cables and length, still not showing, please let me know what else i need to do?
                          well ideally we should verify that the USB cable and port being used are able to send data and power successfully.
                          Which cables are you using? Do they work with other devices? Do you have another Duet that you can test with? A cell phone? A raspberry pi?
                            Reaperrhs
                              Are any of those for a phone or a tablet that requires data transfer to a PC?
                                Reaperrhs
                                Yes, the longest is a data for shure as well as the short one
                                  And you've tested them with a data device and that USB port and it works?
                                    Reaperrhs
                                    Most of them i used for pictures and video transfer from my phone to the computer and work with other boards that i have
                                      Have you tried connecting it to your network with a config file set copied to the SD card?
                                      So you connect the Duet 3 to the PC with the cable.
                                      Do you hear the USB device detected sound?
                                      Does anything show up in device manager when it is connected?
                                      What LEDs light up on the board?
                                      Have you pressed the erase button?
                                      Is the jumper fitted to the erase pins?
                                      How far do you get in this list of steps?
                                      https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Updating_Duet_3_main_board_firmware
                                        Reaperrhs
                                        Can you point me to the files? I would like to download a fresh updated copy and try again, I'm doing it via usb because i don have a raspberry pi
                                          Phaedrux Moderator @Reaperrhs
                                          @Reaperrhs said in Duet3D not connecting to the computer (Please read carefully):
                                          This is why I don't think you've actually read this link.
                                            Reaperrhs
                                            Is first time, i follow a different link thatvwas given to me on the old post, but i follow all the steps you mentioned, no sound
                                            Nothing on yhe device manager, the pin was fit, and the lights are the same on the picture
