    Duet3D not connecting to the computer (Please read carefully)
    Order discussion
    1.8k
    • Reaperrhsundefined
      Reaperrhs
      honestly, i don't understand what do you want me to describe, I follow step by step according to duet, i install all the drivers and programs to get it connected, nothing happens, i place the jumper and erased and still not working, i try 3 different computers and several cables and length, still not showing, please let me know what else i need to do?
        well ideally we should verify that the USB cable and port being used are able to send data and power successfully.
        Which cables are you using? Do they work with other devices? Do you have another Duet that you can test with? A cell phone? A raspberry pi?
          Reaperrhs
            Are any of those for a phone or a tablet that requires data transfer to a PC?
              Reaperrhs
              Yes, the longest is a data for shure as well as the short one
                And you've tested them with a data device and that USB port and it works?
                  Reaperrhs
                  Most of them i used for pictures and video transfer from my phone to the computer and work with other boards that i have
                    Have you tried connecting it to your network with a config file set copied to the SD card?
                    So you connect the Duet 3 to the PC with the cable.
                    Do you hear the USB device detected sound?
                    Does anything show up in device manager when it is connected?
                    What LEDs light up on the board?
                    Have you pressed the erase button?
                    Is the jumper fitted to the erase pins?
                    How far do you get in this list of steps?
                    https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Updating_Duet_3_main_board_firmware
                      Reaperrhs
                      Can you point me to the files? I would like to download a fresh updated copy and try again, I'm doing it via usb because i don have a raspberry pi
                        Phaedrux Moderator @Reaperrhs
                        @Reaperrhs said in Duet3D not connecting to the computer (Please read carefully):
                        This is why I don't think you've actually read this link.
                          Reaperrhs
                          Is first time, i follow a different link thatvwas given to me on the old post, but i follow all the steps you mentioned, no sound
                          Nothing on yhe device manager, the pin was fit, and the lights are the same on the picture
                            Do you have Bossa installed on your PC?
                              Reaperrhs
                              Yes. Yat as well
                                And nothing shows up in Bossa with these steps?
                                To update via USB (using a Windows host):
                                You will need to install Bossa 1.9.1 from https://github.com/shumatech/BOSSA/relea... on your PC.
                                Place a jumper across the ERASE pins on the Duet 3 and power it up to erase the firmware. The Bossa port should appear on your PC (if it doesn't, try pressing the Reset button).
                                The erase jumper is located in the center of the board near the large CPU chip.
                                Remove the ERASE jumper, load Bossa and select the correct COM port. It should identify the device as ATSAM70x20.
                                Check the Erase All, Boot to Flash and Lock boxes
                                Download the latest RRF V3 from here: https://github.com/dc42/RepRapFirmware/r...
                                Browse to the firmware binary, and select Write.
                                When that completes, select Verify.
                                When that completes successfully, press the Reset button on the Duet 3 to restart the Duet in normal mode.
                                Which picture?
                                  Reaperrhs
                                  I try that several times, doesn't work
                                    Reaperrhs
                                      dc42 administrators @Reaperrhs
                                      @Reaperrhs, have you installed the Windows driver for Duet? You can find it in file DuetDriverFiles.zip which is available at https://github.com/dc42/RepRapFirmware/releases/tag/3.01-RC9 and in some earlier releases. You need to unzip the package into a temporary folder, then double-click on the .inf file.
                                      I am in communication with Filastruder about your board.
                                      Reaperrhsundefined 1 Reply Last reply Reply Quote 0
                                        A Former User @Reaperrhs
                                        @Phaedrux said in Duet3D not connecting to the computer (Please read carefully):
                                        it doesn't sound like thats worth while pursuing after
                                          Reaperrhs
                                          i format my memory card by mistake and lost all files
                                            Reaperrhs @dc42
                                            @dc42 the only thing left to is to connect the board to the network using an ethernet cable but unfortunately, I cant files to do that
