I think my new Magnetic Filament Monitor is dead.
Sorry about that. I went in and changed it to S0, and I guess I forgot to uncomment the line.
I’ll hopefully get some useful data tomorrow. -
Thanks.
Unfortunately both we and Filastruder are out of stock of magnetic filament monitors, so it may be a little while before we can get you another one to try. It's the housings we have run out of, so we may be able to send you just the board.
Well, it will be a bit... Hemera gear broke today.
Sorry about the delay in this testing... my Hemera gear broke, then we moved to another city and it took me a while to get the printer going again.
But, that said, I'm having more problems even with the the command changed to S0 for debugging.. I'm still getting pauses for extruder not working. I have commented out the line because I'd really like to at least get a print going. But if there is anything I can check or do, I'm open for suggestions.
@shinook said in I think my new Magnetic Filament Monitor is dead.:
I think we were going to try replacing it if you're still interested in doing that. I'm not sure what the current stock situation is, but check with filastruder if they can replace and if not fill out the form here to see if you can get something directly from Duet. https://www.duet3d.com/warranty
In either case, refer to this thread.
