SOLVED DSF 2.1.1 hangs on apt upgrade with no Duet connected
Or more specifically upgrading DFS hangs when upgrading the reprapfirmware package.
Unpacking duetcontrolserver (2.1.1) over (2.1.0) ... Preparing to unpack .../5-duetruntime_2.1.1_armhf.deb ... Unpacking duetruntime (2.1.1) over (2.1.0) ... Setting up duetruntime (2.1.1) ... Setting up duetwebcontrol (2.1.5) ... Setting up duetcontrolserver (2.1.1) ... Installing new version of config file /opt/dsf/conf/config.json ... Setting up duettools (2.1.1) ... Setting up reprapfirmware (2.1.1-1) ... Progress: [ 84%] [################################################..........]
ps shows
1267 ? Ss 0:00 /usr/bin/dpkg --status-fd 22 --configure --pending 1284 ? S 0:00 /bin/sh /var/lib/dpkg/info/reprapfirmware.postinst co 1286 ? Sl 0:14 /opt/dsf/bin/DuetControlServer -u
killing DCS was only way to proceed, a reasonable timeout for the update process may be needed?
D'oh, this is admittedly a bit of an edge case, borderline corner case.
The update hangs because the Pi thinks it has a Duet connected, but it is just two lonely jumpers across RDY/CS and MISO/MOSI after the loopback testing.
Still, a reasonable timeout should be implemented given that another RRF update could break compatibility with DFS updates in the future causing a legitimate hang.
On the bright side distinguisng between the different states of SPI problems are now much easier when looking at he DCS output so thats good
@bearer said in DSF 2.1.1 hangs on apt upgrade with no Duet connected:
That's the saddest thing I've heard all day.
OK, I must admit I have not tested this particular use-case yet
@chrishamm said in DSF 2.1.1 hangs on apt upgrade with no Duet connected:
fair enough .. but wouldn't the change that caused RC6 and RC7 to not upgrade though DCS share the same fate?
if not then ignore ofc.
@bearer The latest DCS version only asks for the information it really needs for an update (i.e. the
boards
key) to avoid potential incompatibilities. -
gotcha, i thought it was a bigger change to the protocol on top of the spi bus.
case closed.
