    Reporting Buffer Remaining
    Firmware wishlist
    http rrstatus buffer
    • CliveB
      CliveB last edited by
      At present the only way to find out if there is space in the gcode buffer to send another command is by sending a rr_gcode command.
      	NetworkGCodeInput * const httpInput = reprap.GetGCodes().GetHTTPInput();
      	httpInput->Put(HttpMessage, GetKeyValue("gcode"));
      	response->printf("{\"buff\":%u}", httpInput->BufferSpaceLeft());
      would it be possible to add the "buff" value into an existing rr_status or to create another one?
      Would the buffer just be read and not otherwise be affected by
      response->printf("{"buff":%u}", httpInput->BufferSpaceLeft());
      I do not wish to move away from a standard build otherwise I would have a go at implementing the idea.
      Thanks
      Retirement: when you work just as hard but without financial reward!
      You only stop learning when the lid is screwed down.
      www.remap.org.uk www.kyaningacdc.org
      Prusa i3 Mk3 - my workhorse
      chrishamm 1 Reply Last reply Reply Quote 0
        I think it would make more sense to either report the buffer space left in the object model, or change HttpResponder so that if you send an empty command string with rr_gcode, it doesn't try to execute the command but just returns the buffer space. I'll make that second change in the next 3.01-RC release.
        • chrishamm
          chrishamm administrators @CliveB last edited by
          @CliveB For now you can send an empty rr_gcode request to get the remaining buffer space, e.g. http://ormerod/rr_gcode?gcode= is sufficient even though it looks a bit odd.
          But I agree it would make more sense to be able to omit the gcode key if it isn't used.
          Duet software engineer
          dc42 CliveB 2 Replies Last reply Reply Quote 0
            dc42 administrators @chrishamm last edited by
            @chrishamm said in Reporting Buffer Remaining:
            Currently, that will use up 1 byte of buffer space. I've changed it so that in future it won't. But if the buffer is full, it shouldn't matter anyway, the empty GCode line will get thrown away.
            CliveB 1 Reply Last reply Reply Quote 0
            • CliveB
              CliveB @chrishamm last edited by
              @chrishamm Thank you for the response, it will make life a lot easier
              • CliveB
                CliveB @dc42 last edited by
                @dc42 Thank you, fully understood and will solve the problem.
