    bad connection duet maestro RRF3 3.01 RC10 DWC 2.1.5
    Beta Firmware
    419
    • Lc1975undefined
      Lc1975
      Hello.
      Im having a little problem with my duet maestro after a clean install to RRF 3
      Using Firmware:
      RepRapFirmware for Duet 2 Maestro 3.01-RC10 (2020-04-25b3)
      And DWC:
      Duet Web Control 2.1.5
      Until this version never had problem with ethernet.. But now each 1 or 3 minutes loses connection..
      After a M122:
      === Network ===
      Slowest loop: 7.34ms; fastest: 0.02ms
      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
      HTTP sessions: 1 of 8
      Interface state active, link 100Mbps full duplex
      Always shows this:
      29/04/2020, 21:00:51 Connection established
      29/04/2020, 21:00:50 Connection interrupted, attempting to reconnect...
      HTTP request timed out
      29/04/2020, 20:58:07 Connection established
      29/04/2020, 20:58:07 Connection interrupted, attempting to reconnect...
      29/04/2020, 20:56:28 Connection established
      29/04/2020, 20:56:28 Connection interrupted, attempting to reconnect...
      29/04/2020, 20:54:39 Connection established
      29/04/2020, 20:54:39 Connection interrupted, attempting to reconnect...
      29/04/2020, 20:51:57 Connection established
      29/04/2020, 20:51:57 Connection interrupted, attempting to reconnect...
      29/04/2020, 20:50:36 Connection interrupted, attempting to reconnect...
      29/04/2020, 20:49:24 Connection interrupted, attempting to reconnect...
      Can someone help me on this please?
      Regards
        I'm not aware of any recent changes that would make the network less reliable. What was the most recent version that worked reliably? Can you downgrade the firmware to that version? You should be able to continue using DWC 2.1.5 with older firmware.
        • Lc1975undefined
          Lc1975
          I will give a try tomorrow...
          Have to go to work.
          Thanks dc42
          • Lc1975undefined
            Lc1975
            Good morning....
            After installing the previus version....
            FIRMWARE_NAME:
            FIRMWARE_VERSION: 3.01-RC9 ELECTRONICS:
            Duet Maestro 1.0 FIRMWARE_DATE: 2020-04-21b1
            === Network ===
            Slowest loop: 104.72ms; fastest: 0.02ms
            No issue with network connection....
              I've searched the change logs and I can't find anything that would account for a difference in network behaviour between RC9 and RC10. I've just finished testing release 3.01-RC11 on a Maestro and I didn't see any network issues. So please try that version after I publish it later this afternoon.
              • A Former User?
                A Former User @dc42
                @dc42 said in bad connection duet maestro RRF3 3.01 RC10 DWC 2.1.5:
                3.01-RC11
                typo IO_0 became IO_1 in whats new log btw.
                  dc42 administrators @A Former User
                  @bearer said in bad connection duet maestro RRF3 3.01 RC10 DWC 2.1.5:
                  Thanks, fixed.
                  Lc1975undefined 1 Reply Last reply Reply Quote 0
                  • Lc1975undefined
                    Lc1975 @dc42
                    @dc42 ok.
                    Thanks.
                    Going to try when get home.
                    • Lc1975undefined
                      Lc1975
                      After almost 1h of use no problem with the network...
                      RepRapFirmware for Duet 2 Maestro 3.01-RC11 (2020-04-30b3)
                      Duet Web Control 2.1.6
                      Thanks.
                        Thanks. If the problem occurs again, please start a new thread, but you may wish to link to this thread in it.
