    Meta Command Limit
    DSF Development
    • ChrisP
      ChrisP last edited by
      I've been having a play around with meta commands and conditional g-code over the past couple of days to see if/how I can use it to make some tasks a bit more smart and/or automated. Below is an example of a simple script(?) I was experimenting with that when a tool is selected, should display the current tool number, setpoint, current temperature and the difference between the two. For what I was aiming for, I'm only actually interested in the difference value, however, I was building it up bit at a time to make sure I was reading the correct part of the object model.
      However, I believe I've now reached a point where I've filled up a buffer and was wondering a) what the current length limit is (SPI buffer?), b) could it be increased, c) I guess this could possibly be avoided in the future when variables get implemented...?
      I appreciate that my example below is extreme and it's unlikely that anyone would actually be upset if they couldn't this particular example. Therefore, this isn't actually a request to have the limit increased, it's currently more an observation that there is a limit, whether it's likely to be sufficient for other typical use cases, and whether there might be any smarter way of doing this sort of thing?
      So, this works:
      if {state.currentTool == -1}
      	M291 P"No tool selected" S1
      else
      	M291 P{ "Tool:" ^ state.currentTool ^ " | Setpoint:" ^ heat.heaters[tools[state.currentTool].heaters[0]].active ^ " | Current:" ^ heat.heaters[tools[state.currentTool].heaters[0]].current } S1
      This also works:
      else
      	M291 P{ "Difference:" ^ (heat.heaters[tools[state.currentTool].heaters[0]].active - heat.heaters[tools[state.currentTool].heaters[0]].current) } S1
      This, however, throws an exception in DWC of Failed to serialize code.
      else
      	M291 P{ "Tool:" ^ state.currentTool ^ " | Setpoint:" ^ heat.heaters[tools[state.currentTool].heaters[0]].active ^ " | Current:" ^ heat.heaters[tools[state.currentTool].heaters[0]].current ^ " | Difference:" ^ (heat.heaters[tools[state.currentTool].heaters[0]].active - heat.heaters[tools[state.currentTool].heaters[0]].current) } S1
      Here's the log from DCS:
      May 01 12:53:19 starttex DuetControlServer[1779]: [info] Starting macro file 0:/macros/Experimental/target temperatures on channel HTTP
      May 01 12:53:19 starttex DuetControlServer[1779]: [error] Code M291 P{ "Tool:" ^ state.currentTool ^ " | Setpoint:" ^ heat.heaters[tools[state.currentTool].heaters[0]].active ^ " | Current:" ^ heat.heaters[tools[state.currentTool].heaters[0]].current ^ " | Difference:" ^ (heat.heaters[tools[state.currentTool].heaters[0]].active - heat.heaters[tools[state.currentTool].heaters[0]].current) } S1 has thrown an exception
      May 01 12:53:19 starttex DuetControlServer[1779]:    System.ArgumentException: Failed to serialize code
      May 01 12:53:19 starttex DuetControlServer[1779]:  ---> System.ArgumentException: Destination is too short. (Parameter 'destination')
      May 01 12:53:19 starttex DuetControlServer[1779]:    at DuetControlServer.SPI.Serialization.Writer.WriteCode(Span`1 to, Code code) in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/SPI/Serialization/Writer.cs:line 231
      May 01 12:53:19 starttex DuetControlServer[1779]:    at DuetControlServer.SPI.DataTransfer.GetCodeSize(Code code) in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/SPI/DataTransfer.cs:line 523
      May 01 12:53:19 starttex DuetControlServer[1779]:    --- End of inner exception stack trace ---
      May 01 12:53:19 starttex DuetControlServer[1779]:    at DuetControlServer.SPI.DataTransfer.GetCodeSize(Code code) in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/SPI/DataTransfer.cs:line 527
      May 01 12:53:19 starttex DuetControlServer[1779]:    at DuetControlServer.SPI.Channel.Processor.ProcessCode(Code code) in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/SPI/Channel/Processor.cs:line 283
      May 01 12:53:19 starttex DuetControlServer[1779]:    at DuetControlServer.SPI.Interface.ProcessCode(Code code) in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/SPI/Interface.cs:line 211
      May 01 12:53:19 starttex DuetControlServer[1779]:    at DuetControlServer.Commands.Code.Process() in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/Commands/Code.cs:line 425
      May 01 12:53:19 starttex DuetControlServer[1779]:    at DuetControlServer.Commands.Code.ExecuteInternally() in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/Commands/Code.cs:line 337
      May 01 12:53:19 starttex DuetControlServer[1779]: [info] Aborted macro file 0:/macros/Experimental/target temperatures
      May 01 12:53:19 starttex DuetControlServer[1779]: [error] Failed to execute M291 in target temperatures: [ArgumentException] Failed to serialize code
      (edit: I've just tried replacing the M291 commands with echos instead and that errors saying the argument is too long (>255)... so I guess that's the limit?)
        The maximum length of a line of GCode supported by RRF on Duets, excluding leading indentation and trailing comments, is 160 characters. The maximum nesting depth of if- and while-commands is 10. DCS may have different limits.
        dc42 1 Reply Last reply Reply Quote 1
          dc42 administrators @dc42 last edited by dc42
          PS - I can increase the maximum line length on Duet 3 because there is plenty of RAM available. Not so easy on Duet 2.
          • ChrisP
            Thanks for that! As it happens, I'm actually using this on setups with D3 with SBC,and I guess in these cases the limit is in DCS?
            However, I do have other systems running D2, so this is still really useful to know.
