    DWC 2.1.7 - Bug (define area for delta mesh compensation)
    Duet Web Control
    • garyd9undefined
      garyd9
      RRF 3.01-RC12, DWC 2.1.7, duet3, standalone:
      @chrishamm, I really appreciate that you recently fixed the prompt for mesh compensation parameters on Delta printers (dashboard -> "compensation+calibration" -> "define area...") in a previous release. However, while it's prompting for the correct things, it seems to be sending an incorrect M557 command.
      For mesh compensation on my delta, I typically use a radius of 140 and spacing of 20. The correct M557 command for that is: "M557 R140 S20" I can validate the correct parameters are set by running M557 in the console with no parameters:
      Grid: X-120.0:120.1, Y-120.0:120.1, radius 140.0, X spacing 20.0, Y spacing 20.0, 169 points
      Note the radius and spacing are set.
      However, if I use the DWC interface ((dashboard -> "compensation+calibration" -> "define area...") ) to try and set a "Probe Radius" of 140 and "Spacing" of 20, running M557 from the console gives a very different output:
      Grid: X-120.0:120.1, Y-120.0:120.1, radius -1.0, X spacing 20.0, Y spacing 20.0, 169 points
      Note that the radius is set to "-1" and not "140."
      I don't know the exact command that DWC is sending the duet that results in the above M557 configuration. (Didn't older versions of DWC show commands sent in the console? I guess that stopped with DWC2?)
      "I'm not saying that you are wrong - I'm just trying to fit it into my real world simulated experience."
      • chrishammundefined
        chrishamm administrators
        Thanks for the note, I'll fix that too.
        Duet software engineer
