    Extruders, heaters and temp probe not working
    Firmware installation
    • Vital1undefined
      Vital1
      Can anyone shed some light on our current config file? All of the motors are currently working, except for the extruders, along with the heaters and temp probes (we have tried thermocouples and thermistors). We do have a daughter board but not tried it yet
      We started off using the online configuration tool, but have had to change plenty of things to get it working, but it is just this problem (which is hopefully something simple).
      The extruder has worked in the past when we initially got everything talking and running a gcode, but they only turned at the end of the print (that was before we changed the config)
      ; Configuration file for Duet WiFi (firmware version 1.17)
      ; generated by RepRapFirmware Configuration Tool on Mon Mar 27 2017 16:43:36 GMT+0100 (GMT Daylight Time)
      M111 S0 ; Debugging off
      G21 ; Work in millimetres
      M208 X1200 Y2300 Z900 S0 ; Set axis maxima
      M574 X1 Y1 Z1 S0 ; Define active high microswitches
      M558 P1 X0 Y0 Z0 H5 F120 T9000 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds
      G31 P600 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
      M557 X15:2285 Y15:2085 S20 ; Define mesh grid
      M584 Z5 ; Apply custom drive mapping
      M569 P5 S0 R1 T2 ; Drive 2 goes forwards
      M569 P4 S1 ; Drive 4 goes forwards
      M350 X16 Y16 Z10 E16:16 I1 ; Configure microstepping with interpolation
      M92 X213.33 Y213.33 Z5000 E495:495 ; Set steps per mm
      M566 X900 Y900 Z50 E120:120 ; Set maximum instantaneous speed changes (mm/min)
      M203 X48000 Y48000 Z100 E1200:1200 ; Set maximum speeds (mm/min)
      M201 X100 Y100 Z20 E50:50 ; Set accelerations (mm/s^2)
      M906 X2000 Y2000 Z2000 E600:600 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M143 S260 ; Set maximum heater temperature to 260C
      M140 H-1 ; Disable heated bed
      M305 P2 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 2
      M563 P0 D0 H1 ; Define tool 0
      M563 P1 D1 H2 ; Define tool 1
      G10 P1 X0 Y0 Z0 ; Set tool 1 axis offsets
      G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
      M552 S0 ; Disable network
      M106 P1 S1 I0 F500 H1:2 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P2 S1 I0 F500 H1:2 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
      I have just looked at the tfree, tpost, tpre files and I am guessing that they are the issues, but not sure what needs to go in there.
      tfree is
      ; tfree0.g
      ; called when tool 0 is freed
      tpost is
      ; tpost0.g
      ; called after tool 0 has been selected
      ; Wait for set temperatures to be reached
      M116 P0
      tpre is
      ; tpre0.g
      ; called before tool 0 is selected
      • Whitewolfundefined
        Whitewolf
        It wont be those files, it appears that you might have a default thermisistor settings. Have you tried targeting your specific thermocouple or thermisistor?
        Knowing the correct OHMs at room temp and full temp then plugging those into the calculator on the online configurator will go along way.
        You should then be able to run autotune on each of the heaters.
        Exploring the universe wherever the tech blows
          Please can you clarify in what way(s) the heaters and temperature probes are not working. Are you selecting a tool before trying to heat up the extruder(s)?
