SOLVED What's the best practice to test G-code during a debug session?
Hi everyone 👋
my name is Mario - obviously I'm new here - and I struggling with executing specific G- & M-commands on a Duet3 board while a debugger is active.
The firmware debugging itself works fine. I'm able to build and start a debug session directly within Eclipse.
However, it became tricky for me when I wanted to execute specific G-/M-commands during a debug session.I tried to ...
(1) Send commands using the Duet Software Framework, but I'm not able to get a connection during a debug session.
(2) Send commands using Pronterface (https://www.pronterface.com), but it didn't work either.
(3) Load commands from SD cards. This approach works, but to me it is not really nice workflow. So, I really would like to avoid using a SD cardHere, my actual question is:
What's the best practice to test single & multiple G- & M-Commands during a debug session?Thanks,
MarioHardware
- Duet 3 Board (ATSAM70Q20)
- Segger JLink Plus
- Raspberry Pi Model 3 B+
- Notebook (Windows/OSX)
Software
- Duet 3 Firmware
- RepRapFirmware:v3.01-dev
- RRFLibraries:dev
- CoreNG:dev
- FreeRTOS:master
- DuetWiFiSocketServer:master
- Segger JLink Remote Server
v6.72c
- Raspberry Pi with DuetPi (downloaded on 2020-05-13)
- Eclipse
2020-03
- GNU Tools for Arm Embedded Processor
v9.2.1
(0-2019-q4-major
Setup
- Segger connects via SWD ping to the Duet3 board
- Raspberry Pi connects via USB to the Segger
- The Raspberry Pi works as remote debug server
- Eclipse connects via the network to the remote debug server on the Raspberry Pi
You could try sending the command via the PanelDue serial port. Caution: it uses 3.3V signal levels; 5V will damage the MCU.
To trace codes being executed from DSF, stop the service and start it with debugging output:
sudo systemctl stop duetcontrolserver sudo /opt/dsf/bin/DuetControlServer -l debug -r
Whenever you see e.g.
HTTP: Sent XXXX
in the log, you know that the code has been processed in DCS and that it has been sent to RRF for further execution.
@dc42 Thanks for the extremely fast response. Unfortunately, I don't have a PanelDue.
@chrishamm Starting the DuetControlServer in debug mode might help understanding what's going on.What I don't understand is, why the DuetControlServer is not able to connect with the Duet3 board via ribbon cable while a debug session is active. Is this expected behavior or am I missing something here?
@mpreishuber DCS works best with low latencies and if it cannot establish a connection to the Duet 3 within a reasonable time, it will terminate again. Of course, if you pause the code execution on the MCU, the board won't be able to answer to DCS.
@dc42 said in What's the best practice to test G-code during a debug session?:
Duet 3 Hardware Overview web page says: "The inputs will tolerate up to 30V. The outputs are 3.3V signals levels with 470R series resistors."
I would like to know how can you damage MCU with 5V if input is tolerating up to 30V?
Best regards
@Sejl said in What's the best practice to test G-code during a debug session?:
Best regards
I stand corrected. On Duet 3, PanelDue connects to the IO_0 connector, which is indeed tolerant of 30V on the input pin. On Duet 2 and Duet 085 it tolerates 3.3V maximum.
Best regards
Thank you!
