G30 S-2 Multi-touch support
  • I have two (2) z probes (K0 and K1) both configured in M558 with the A and S parameters.
    G30 without any parameters (defaulting to probe 0) works as expected touching off at least 2x, and more as needed such the deviation is less than the value specified in the S parameter of M558.
    When I try to use G30 S-2 K1, I do not get the multi-touch effect. It only touches off once.
    Is it possible to get this support?
