    Jog Command Toolbar Hidden
    Duet Web Control
    • TheFabricator03undefined
      TheFabricator03
      Hi all,
      I am using DWC2 for klipper and I am having this problem. I am trying to get the jog command bar to show up but I cannot work out how. Reading the manual (https://duet3d.dozuki.com/Wiki/Duet_Web_Control_Manual) it says that the interface is dynamic and features will only show if configured but it does not say how to configure the features.
      When I load DWC2 I get this,
      I want to have this,
      The jog bar loads when I first open the web interface and then dissappears.
      Any thoughts?
        That looks like a difference between DWC 1 and DWC 2. What does Klipper support?
          TheFabricator03
          Not sure but its DWC2,
          https://klipper.info/klipper-+-dwc2-1/things-to-know-about-klipper-and-dwc2
          How can I configure the interface? I just want to add the jog bar that loads when I load the interface but quickly disappears. I would of thought it would be rather simple.
            My guess is the klipper isn't reporting the number of visible axes correctly in the rr_status response, or you have somehow configured klipper to have zero visible axes.
