Duet rejetct the HTTP request
  • Your Duet rejected the HTTP request: page not found
    Check that the SD card is mounted and has the correct files in its /www folder
    === Diagnostics ===<LF>RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later<LF>Board ID: 08DJM-9178L-L2MSD-6JKF6-3SN6L-1THGR<LF>Used output buffers: 1 of 24 (2 max)<LF>=== RTOS ===<LF>Static ram: 25712<LF>Dynamic ram: 93368 of which 0 recycled<LF>Exception stack ram used: 284<LF>Never used ram: 11708<LF>Tasks: NETWORK(ready,812) HEAT(suspended,1232) MAIN(running,3768) IDLE(ready,160)<LF>Owned mutexes:<LF>=== Platform ===<LF>Last reset 00:02:33 ago, cause: reset button or watchdog<LF>Last software reset time unknown, reason: User, spinning module GCodes, available RAM 11804 bytes (slot 3)<LF>Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d<LF>Error status: 1<LF>Free file entries: 10<LF>SD card 0 detected, interface speed: 20.0MBytes/sec<LF>SD card longest block write time: 0.0ms, max retries 0<LF>MCU temperature: min 41.4, current 42.2, max 42.4<LF>Supply voltage: min 1.6, current 1.7, max 1.7, under voltage events: 0, over voltage events<Warning: Maximal number of bytes per line exceeded! Check the end-of-line settings or increase the limit in the advanced terminal settings.>
  • Moderator
    Please change the line endings in YAT so we can see the complete and properly formatted output.
    Have you tested the SD card in your PC?
    Are the /www files actually present?
  • Thank you replay
    I uploaded www folder know working
