RRF2 to RRF3 and Laser
  • So for the most part I have successfully converted to RRF3. I just completed a print. Now I am trying to get the laser to work as I had with RRF2. I cannot get the Duet to control the laser. What I used to do was have a directory under sys named laser. When I wanted to use the laser I would switch to this directory and run the config.g file in that directory. This is the entry in that file to run the laser using Fan2
    ; Laser Fan
    M106 P2 I-1 ; Disable Fan2 for laser PWM control
    M452 P2 R255 F4000 ; switch to laser mode using the FAN-2 output pins to control the laser
    In RRF3 I am trying to do it a little differently. First I designated a tool "Laser" in the config.g with this entry:
    M563 P2 S"Laser" ;Define tool 2 as laser
    Then I have a macro to go into Laser mode with this:
    ; Switch to Laser control
    M452 F2 Q4000 ; laser uses Fan2 pin, PWM frequency 4000Hz
    It switches to Laser mode ok but does not control it. I cannot turn it on (M3 Sxx ) or turn it off (M5 or M3 S0). It stays on constantly. I also tried inverting Fan2 but it did not make any difference.
    I know I am missing something but I don't know what.
    Thanks
    George
  • Moderator
    Just to clarify, are you using M505 to switch configs?
    https://duet3d.dozuki.com/Wiki/Gcode#Section_M505_Set_configuration_file_folder
    Part of the problem is probably M106 P2 I-1 ; Disable Fan2 for laser PWM control as the inversion of pins is now controlled by M950 in RRF3.
  • I was probably confusing.
    I was using M505 in V2 using a sub directory. However I am now trying to accomplish this without using a sub-directory by creating a tool called laser and then using a macro to switch to laser mode. In all this I want to use Fan2 to use the PWM control form 0 to 255.
  • Moderator
    Alright, so where is the M950 command to define the pin you want to use?
  • Its in the config.g file:
    ; generated by RepRapFirmware Configuration Tool v3.1.3 on Mon Jun 15 2020 11:14:50 GMT-0600 (Mountain Daylight Time)
    M550 P"My Printer" ; set printer name
    M669 K1 ; select CoreXY mode
    M552 S1 ; enable network
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    M569 P0 S0 ; physical drive 0 goes backwords
    M569 P4 S0 ; physical drive 4 goes backward
    M584 X0 Y1 Z2:4 E3 ;two Z Motors connected to driver outputs A and E1
    M671 X-20:310 Y0:0 S2 ;Leadscrew at left (connected to Z) and right connected to E1) of X axis
    M350 X16 Y16 Z16 E16 U16 I1 ; configure microstepping with interpolation
    M92 X101.84 Y104.96 Z402.42 U402.42 E2892.00 ; set steps per mm
    M566 X500.00 Y500.00 Z100.00 U100.00 E60.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X10000.00 Y10000.00 Z6000.00 U6000.00 E8000.00 ; set maximum speeds (mm/min)
    M201 X800.00 Y800.00 Z30.00 U30.00 E120.00 ; set accelerations (mm/s^2)
    M906 X1200.00 Y1200.00 Z800.00 U800.00 E500.00 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X-25 Y-15 Z0 S1 ; set axis minima
    M208 X330 Y340 Z300 S0 ; set axis maxima
    M574 Z1 S2 ; configure Z-probe endstop for low end on Z
    M558 P9 C"^zprobe.in" H3 F120 T4800 ; set Z probe type to bltouch and the dive height + speeds
    G31 P25 X30 Y-10 Z.48 ; set Z probe trigger value, offset and trigger height
    M557 X15:285 Y15:275 P5:5 ; define mesh grid ; define mesh grid
    M376 H10
    M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 R4700 ; configure sensor 0 as thermistor on pin bedtemp
    M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
    M950 F2 C"!fan2" Q1000 ; create fan 2 on pin fan1 and set its frequency
    M106 P2 S255 H-1 ; set fan 2 value. Thermostatic control is turned off
    M563 P0 S"E3D_V6" D0 H1 F0 ; define tool 0
    M563 P2 S"Laser" ;Define tool 1 as laser
    M501
  • Moderator
    Unfortunately I'm not familiar enough with laser to say what should or shouldn't work in RRF3 or not.
    I'll move this to the general discussion area for some more visibility.
  • Thanks. I was going to try that today
