    how do i revert back the firmware
    Firmware installation
    782
    • downshift64undefined
      downshift64
      how do i go back to i think was 2.0.7 from 3.1.1 firmware on the duet 2 wifi ,,, i can not figure out how to change everything
      config.g
        You can downgrade to version 2.05.1 from 3.1.1 in the usual way, by uploading the 2.05.1 firmware binary through Duet Web Control.
          downshift64
          thank you i will give that a try
            downshift64
            i am getting an error
            Error: M997 In-application programming binary "duet2combinedIAP.bin" not found
              downshift64
              Error M997 SO:1
              • A Former User?
                A Former User @downshift64
                @downshift64 said in how do i revert back the firmware:
                if you upload the 2.05.1 zipped release that file will be included
                Error M997 SO:1
                Please note 0 and not O
                  downshift64
                  ok i uploaded that zip it loaded all 14 files then asked if i wanted to install i said yes then i got the error
                  • A Former User?
                    A Former User
                    hm, my bad, that file is called iap4e.bin in 2.05.1 - so it would suggest the problem is that its missing in your 3.x installation.
                    https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2CombinedIAP.bin upload to /sys
                      downshift64
                      iam trying to get away from the 3.x i dont understand it i am lost just trying to get it back to the running state it was before i dont know why but decided to update the firmware now to get back to where i was ..
                      • A Former User?
                        you still need to upload that file to let 3.x complete the downgrade (the running 3.x firmware will look for Duet2CombinedIAP.bin to perform the downgrade.
                        (its not the RepRapFirmware itself, just a support application that deals with the firmware update)
                          downshift64
                          thank you very much that fixed it, it is back to normal thank you so much,,,,,i really wish i knew more and could upgrade to the 3.1.1 firmware but its bit to much for me
