    Which branch?
    Firmware developers
    • trayracingundefined
      trayracing
      Is there a page that describes which branch is best for a given purpose? I'm looking to implement some new kinematics with a Duet 2 Wifi. Which branch should I be starting from at this point? Thanks
        Either the v3.02-dev branch if you don't mind working with the latest code, or the 3.01 branch (but then you will have to merge your changes to the 3.02 branch later).
          trayracing
          Thanks. Which branch's build instructions should I follow? The dev branch instructions mention v3, and v3.02-dev build instructions look older.
            Follow the build instructions on /dev.
            trayracingundefined 1 Reply Last reply Reply Quote 0
              trayracing @dc42
              Thanks @dc42
