    Duet3d dropping network connection
    Duet Web Control
    • MadGuttsundefined
      MadGutts
      Re: Duet Ethernet Connection Dropping
      Hi have a brand new Duet 3d suppied by my machine manufacturer and i have followed their processes to configure and setup the board...
      However it wouldnt keep the static ip address nor connect when i first ran the terminal set up, so found a thread here to set it up with a DHCP enabled, this worked and i could get the card to talk to the network... however a constant ping shows dropped connections regularly, so i went back into all the settings and changed the lan address to static and plugged the card directly into my laptop - no router...
      Although it will connect, there are still ping drop outs and everytime i try to upload a file it takes 10 minutes and tells me the network was interupted....
      im guessing the card is faulty as surely it should constantly drop pings on a direct connection!
        Please send M122 in the console and post the response here.
