Duet 2 Wifi firmware upgrade issue
  • Hi, I bought a second hand printer with duet 2 wifi board on.
    It was running old firmware but I have now manage to upgrade to 3.0
    Board: Duet WiFi 1.02 or later
    Here are the infor from diagnostic.
    Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.0 (2020-01-03b3)
    Duet WiFi Server Version: 1.23
    When I'm trying to upload Duet2and3Firmware-3.1.1.zip it upload everything okay but when pressing install button it fails on
    In-application programming binary "Duet2CombinedIAP.bin" not found.
    Have double checked that the file are in the zipfile.
    Any idea?
    Thank you.
    Check that Duet2CombinedIAP.bin is present in the /sys folder of the SD card.
  • Hi, yes the files are there and now when I powered upp the board does not connect to router anymore. I also tried to add M587 S"your-network-ssid" P"your-network-password" and M552 S1 in the config file. I guess I need to connect it with usb and start over.
  • I think I solved it by reflash it by usb and hopefully evrything looks okay for 3.1.1 now.
    RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
    Used output buffers: 3 of 24 (15 max)
    Static ram: 27980
    Dynamic ram: 93888 of which 44 recycled
    Exception stack ram used: 284
    Never used ram: 8876
    Tasks: NETWORK(ready,384) HEAT(blocked,880) MAIN(running,1912) IDLE(ready,80)
    Owned mutexes:
    Last reset 00:05:26 ago, cause: software
    Last software reset at 2020-03-21 18:43, reason: User, spinning module GCodes, available RAM 9980 bytes (slot 0)
    Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
    Error status: 0
    MCU temperature: min 32.3, current 32.5, max 32.8
    Supply voltage: min 1.6, current 1.6, max 1.7, under voltage events: 0, over voltage events: 0, power good: no
    Driver 0: ok, SG min/max not available
    Driver 1: ok, SG min/max not available
    Driver 2: ok, SG min/max not available
    Driver 3: ok, SG min/max not available
    Driver 4: ok, SG min/max not available
    Date/time: 2020-07-05 16:08:33
    Cache data hit count 579235577
    Slowest loop: 5.95ms; fastest: 0.09ms
    === Storage ===
    Free file entries: 10
    SD card longest read time 1.0ms, write time 0.0ms, max retries 0
    Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
    === MainDDARing ===
    Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
    === AuxDDARing ===
    Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
    Segments left: 0
    Movement lock held by null
    HTTP is idle in state(s) 0
    Telnet is idle in state(s) 0
    File is idle in state(s) 0
    USB is idle in state(s) 0
    Aux is idle in state(s) 0
    Trigger is idle in state(s) 0
    Queue is idle in state(s) 0
    Daemon is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 200.80ms; fastest: 0.08ms
    Responder states: HTTP(2) HTTP(2) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
    HTTP sessions: 2 of 8
    • WiFi -
      Network state is active
      Failed messages: pending 0, notready 0, noresp 1
      WiFi firmware version 1.23
      WiFi MAC address bc:dd:c2:33:b9:4b
      WiFi Vcc 3.29, reset reason Unknown
      WiFi flash size 4194304, free heap 23704
      WiFi IP address 192.168.2.20
      WiFi signal strength -46dBm, reconnections 0, sleep mode modem
      Socket states: 2 2 0 0 0 0 0 0
