    IR Probe issue after 3.1.1 update from 3.0
    Firmware installation
    753
    • Adamfilipundefined
      Adamfilip
      Just installed 3.1.1 update from 3.0 Duet2wifi with IR Probe, worked fine with 3.0 but now wont get triggered
      previously had BLtouch
      CoreXY machine
      M950 H3 C"nil"                                 ; Disable heaters h7 to free up pins
      M558 P1 C"^zprobe.in" H5 F800 T2000            ; set Z probe type
      M950 S0 C"exp.heater3"                         ; create servo pin 0 for BLTouch
      G31 X0 Y-40 Z2.65		; Z probe trigger offset, high Z number closer means to bed (LARGER Z MEANS CLOSER BED)
      M557 X10:290 Y10:290 S25                         ; define mesh grid
      ; homeall.g
      ; called to home all axes
      ; generated by RepRapFirmware Configuration Tool v2.1.5 on Wed Jan 08 2020 19:38:55 GMT-0500 (Eastern Standard Time)
      M400			; make sure everything has stopped before we make changes
      G91			; use relative positioning
      G1 H2 Z20 F6000    	; lift Z relative to current position
      G1 H1 Y-350 F3000 	; move quickly to Y axis endstop and stop there (first pass)
      G4 P500			; wait 500msec
      G1 Y0			; move away from home
      G1 H1 X-350 F3000 	; move quickly to X axis endstop and stop there (first pass)
      G90			; back to absolute positioning
      G1 X150 Y150 F3000 	; Centre Print head
      G30
      G1 X0 Y0 F2000 		; Head To Origin
        droftarts administrators @Adamfilip
        @Adamfilip Is it a Duet IR probe, or something else? You shouldn't need to invert the Z-probe pin. You also don't need these two lines:
        Also: M558 P1 C"^zprobe.in" H5 F800 T2000
        F800 (13.33mm/s) is VERY fast for probing, I'm not sure you'll get very repeatable results. Try F200. You can speed up the travel speed 'T' if you want.
        Finally, G31 X0 Y-40 Z2.65: you've got quite a Y offset. You may find that any rotation of the X carriage around the X axis magnifies the probe movement, and doesn't represent the height of the nozzle off the bed. It's better to put the probe physically in line with the nozzle in the X axis, if possible, so Y offset is 0, with an X offset.
        My config for a Duet IR probe, on a Cartesian bed-slinger:
        M558 P1 C"zprobe.in" H5 F120 T6000                 ; set Z probe type to unmodulated and the dive height + speeds
        G31 P500 X20 Y0 Z1.25                              ; set Z probe trigger value, offset and trigger height
        M557 X-85:85 Y-85:85 P5                            ; define mesh grid
          Adamfilip
          Thanks for the info. removing those lines fixed the issue.
          I also slowed it down as you suggested.
          I am unable to move the probe location. just isnt convenient for my machine
            Adamfilip
            finding the Duet IR Probe is being less reliable detecting a surface then it was with 3.0. I just ran grid mesh, and it did a few probings then gave me an error.. Z probe was not triggered. im using a build tak black surface. never caused me an issue before. not sure if it matters but the Sensor Zprobe shows a value of 88 when not near surface and 400-500 when probing
              dc42 administrators @Adamfilip
              @Adamfilip said in IR Probe issue after 3.1.1 update from 3.0:
              Check that you are using "zprobe.in" as the port name in the M558 command, not "^zprobe.in".
                Adamfilip
                Hmm I made that adjustment. ("zprobe.in")
                unfortunately its still giving me probing issues, not detecting reliably now
                M558 P1 C"zprobe.in" H5 F200 T2000            ; set Z probe type
                When I watch it do the probing the light comes on. but it still plunges down farther
                  You have no P value in your G31 command, which could be part of the problem. The correct value for the IR sensor is P500. Alse check that you don't have a G31 command in config-override.g, or another one in config.g.
                  What readings do you get from the Z probe now? It should be very close to 0 when the probe is not triggered, about 465 when it is close to being triggered, and about 535 when it is triggered and the LED is on.
                    Adamfilip
                    Revised
                    G31 X0 Y-40 Z2.65 P500		; Z probe trigger offset, high Z number closer means to bed (LARGER Z MEANS CLOSER BED)
                    The Z probe reading fluctuates alot.. when machine is idle.. 80-100 typical, not close to zero..
                    last time i tried. it homed fine once. but when i tried to do Grid compensation. it failed on third probing
                    nothing is congfig overide related
                      Adamfilip
                      It does give off 4 flashed during start up
                        Clean the sensor with a cotton bud and some IPA?
                          Adamfilip
                          I Cleaned the sensor and its still glitching.
                          after updating firmware, its not working reliably..
                            Adamfilip
                            Not sure what else to try.. its not working 😞
                            ; homeall.g
                            G30
                            Config
                            G90                                              ; send absolute coordinates...
                            M83                                              ; ...but relative extruder moves
                            M550 P"TitanXY"                                  ; set printer name
                            M667 S1                                          ; select CoreXY mode
                            M552 S1                                          ; enable network
                            M586 P0 S1                                       ; enable HTTP
                            M586 P1 S0                                       ; disable FTP
                            M586 P2 S0                                       ; disable Telnet
                            M569 P0 S0                                      ; physical drive 0 goes backwards
                            M569 P1 S0                                    ; physical drive 1 goes backwarsa
                            M569 P2 S0                                       ; Z physical drive 2 goes backwards
                            M569 P3 S1                                       ; Extruder physical drive 3 goes Forwards
                            M584 X0 Y1 Z2 E3                                 ; set drive mapping
                            M350 X32 Y32 Z32 I0                              ; configure microstepping without interpolation
                            M350 E16 I1                                      ; configure microstepping with interpolation
                            M92 X400 Y400 Z1593 E409             ; set steps per mm
                            M566 X600 Y600 Z20 E800 ; Set maximum instantaneous speed changes (mm/min)
                            M203 X9000 Y9000 Z1500 E10000 ; Set maximum speeds (mm/min)
                            M201 X1000 Y1000 Z250 E5000 ; Set accelerations (mm/s^2)
                            M906 X1200 Y1200 Z1500 E1300 I30 ; Set motor currents (mA) and motor idle factor in per cent
                            M84 S30 ; Set idle timeout
                            M572 D0 S0.15 ; Pressure Advance                                        ; Set idle timeout
                            M208 X-7 Y-22 Z0 S1                                 ; set axis minima
                            M208 X312 Y331 Z300 S0                           ; set axis maxima
                            M574 X1 S1 P"xstop"   ; X min active high endstop switch
                            M574 Y1 S1 P"ystop"   ; Y min active high endstop switch
                            G31 P500 X0 Y-40 Z2.65 		; Z probe trigger offset, high Z number closer means to bed (LARGER Z MEANS CLOSER BED)
                            M308 S0 P"bedtemp" Y"thermistor" T100000 B4138   ; configure sensor 0 as thermistor on pin bedtemp
                            M950 H0 C"bedheat" T0                            ; create bed heater output on bedheat and map it to sensor 0
                            M140 H0											; Map heated bed to heater 0
                            M143 H0 S120                                     ; set temperature limit for heater 0 to 120C
                            M307 H0 A61.9 C160.5 D1.3 B0 S0.5 v24.4          ; disable bang-bang mode for the nozzle heater and set PWM limit
                            M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
                            M950 H1 C"e0heat" T1                             ; create nozzle heater output on e0heat and map it to sensor 1
                            M143 H1 S285; set temperature limit for heater 1 to 280C
                            M307 H1 A310.2 C150.5 D3.5 B0 S1 v24.3		;NEW
                            ;M307 H1 A493 C243 D3.9 B0 S0.9 v24.3          ; disable bang-bang mode for the nozzle heater and set PWM limit
                            M950 F0 C"fan0" Q500                             ; create fan 0 on pin fan0 and set its frequency
                            M106 P0 S0 H-1                                   ; set fan 0 value. Thermostatic control is turned off
                            M950 F1 C"fan1" Q500                             ; create fan 1 on pin fan1 and set its frequency
                            M106 P1 S1 H1 T45                                ; set fan 1 value. Thermostatic control is turned on
                            M950 F2 C"fan1" Q500                             ; create fan 2 on pin fan1 and set its frequency
                            M106 P2 S1 H1 T45                                ; set fan 2 value. Thermostatic control is turned on
                            M563 P0 D0 H1 F0                                 ; define tool 0
                            G10 P0 X0 Y0 Z0                                  ; set tool 0 axis offsets
                            G10 P0 R0 S0                                     ; set initial tool 0 active and standby temperatures to 0C
                              Adamfilip
                                Is this a Duet IR sensor or a clone? Was it purchased recently?
                                  Adamfilip
                                  its a Duet sensor.. not clone. purchased 4 months ago
                                    Adamfilip
                                    I reduced the trigger value from 500 down to 400 and it seems to be working again. before updating firmware it worked fine at 500
                                      Phaedrux Moderator @Adamfilip
                                      Is it working better now?
                                        Adamfilip
                                        no, I spoke too soon!
                                        It does trigger more consistently but its all over the place now
                                        probing.JPG l)
                                          Adamfilip
                                          Should i use M558 P2 instead of P1?
                                            Adamfilip
                                            I ran a Mesh compensation sequence and I noticed that when it was probing. While watching the Z probe values.. sometimes the Probe value was around 100 between probings and other times it was zero.. makes me wonder if there is a wire issue
