    IR Probe issue after 3.1.1 update from 3.0
    Firmware installation
    782
      droftarts administrators @Adamfilip
      @Adamfilip Is it a Duet IR probe, or something else? You shouldn't need to invert the Z-probe pin. You also don't need these two lines:
      M950 H3 C"nil"                                 ; Disable heaters h7 to free up pins
      M950 S0 C"exp.heater3"                         ; create servo pin 0 for BLTouch
      Also: M558 P1 C"^zprobe.in" H5 F800 T2000
      F800 (13.33mm/s) is VERY fast for probing, I'm not sure you'll get very repeatable results. Try F200. You can speed up the travel speed 'T' if you want.
      Finally, G31 X0 Y-40 Z2.65: you've got quite a Y offset. You may find that any rotation of the X carriage around the X axis magnifies the probe movement, and doesn't represent the height of the nozzle off the bed. It's better to put the probe physically in line with the nozzle in the X axis, if possible, so Y offset is 0, with an X offset.
      My config for a Duet IR probe, on a Cartesian bed-slinger:
      M558 P1 C"zprobe.in" H5 F120 T6000                 ; set Z probe type to unmodulated and the dive height + speeds
      G31 P500 X20 Y0 Z1.25                              ; set Z probe trigger value, offset and trigger height
      M557 X-85:85 Y-85:85 P5                            ; define mesh grid
      • Adamfilipundefined
        Adamfilip
        Thanks for the info. removing those lines fixed the issue.
        I also slowed it down as you suggested.
        I am unable to move the probe location. just isnt convenient for my machine
          Adamfilip
          finding the Duet IR Probe is being less reliable detecting a surface then it was with 3.0. I just ran grid mesh, and it did a few probings then gave me an error.. Z probe was not triggered. im using a build tak black surface. never caused me an issue before. not sure if it matters but the Sensor Zprobe shows a value of 88 when not near surface and 400-500 when probing
            dc42 administrators @Adamfilip
            @Adamfilip said in IR Probe issue after 3.1.1 update from 3.0:
            Check that you are using "zprobe.in" as the port name in the M558 command, not "^zprobe.in".
              Adamfilip
              Hmm I made that adjustment. ("zprobe.in")
              unfortunately its still giving me probing issues, not detecting reliably now
              M558 P1 C"zprobe.in" H5 F200 T2000            ; set Z probe type
              G31 X0 Y-40 Z2.65		; Z probe trigger offset, high Z number closer means to bed (LARGER Z MEANS CLOSER BED)
              M557 X10:290 Y10:290 S25                         ; define mesh grid
              When I watch it do the probing the light comes on. but it still plunges down farther
                You have no P value in your G31 command, which could be part of the problem. The correct value for the IR sensor is P500. Alse check that you don't have a G31 command in config-override.g, or another one in config.g.
                What readings do you get from the Z probe now? It should be very close to 0 when the probe is not triggered, about 465 when it is close to being triggered, and about 535 when it is triggered and the LED is on.
                  Adamfilip
                  Revised
                  G31 X0 Y-40 Z2.65 P500		; Z probe trigger offset, high Z number closer means to bed (LARGER Z MEANS CLOSER BED)
                  The Z probe reading fluctuates alot.. when machine is idle.. 80-100 typical, not close to zero..
                  last time i tried. it homed fine once. but when i tried to do Grid compensation. it failed on third probing
                  nothing is congfig overide related
                    Adamfilip
                    It does give off 4 flashed during start up
                      Clean the sensor with a cotton bud and some IPA?
                        Adamfilip
                        I Cleaned the sensor and its still glitching.
                        after updating firmware, its not working reliably..
                          Adamfilip
                          Not sure what else to try.. its not working 😞
                          ; homeall.g
                          ; called to home all axes
                          ; generated by RepRapFirmware Configuration Tool v2.1.5 on Wed Jan 08 2020 19:38:55 GMT-0500 (Eastern Standard Time)
                          M400			; make sure everything has stopped before we make changes
                          G91			; use relative positioning
                          G1 H2 Z20 F6000    	; lift Z relative to current position
                          G1 H1 Y-350 F3000 	; move quickly to Y axis endstop and stop there (first pass)
                          G4 P500			; wait 500msec
                          G1 Y0			; move away from home
                          G1 H1 X-350 F3000 	; move quickly to X axis endstop and stop there (first pass)
                          G90			; back to absolute positioning
                          G1 X150 Y150 F3000 	; Centre Print head
                          G30
                          G1 X0 Y0 F2000 		; Head To Origin
                          Config
                          G90                                              ; send absolute coordinates...
                          M83                                              ; ...but relative extruder moves
                          M550 P"TitanXY"                                  ; set printer name
                          M667 S1                                          ; select CoreXY mode
                          M552 S1                                          ; enable network
                          M586 P0 S1                                       ; enable HTTP
                          M586 P1 S0                                       ; disable FTP
                          M586 P2 S0                                       ; disable Telnet
                          M569 P0 S0                                      ; physical drive 0 goes backwards
                          M569 P1 S0                                    ; physical drive 1 goes backwarsa
                          M569 P2 S0                                       ; Z physical drive 2 goes backwards
                          M569 P3 S1                                       ; Extruder physical drive 3 goes Forwards
                          M584 X0 Y1 Z2 E3                                 ; set drive mapping
                          M350 X32 Y32 Z32 I0                              ; configure microstepping without interpolation
                          M350 E16 I1                                      ; configure microstepping with interpolation
                          M92 X400 Y400 Z1593 E409             ; set steps per mm
                          M566 X600 Y600 Z20 E800 ; Set maximum instantaneous speed changes (mm/min)
                          M203 X9000 Y9000 Z1500 E10000 ; Set maximum speeds (mm/min)
                          M201 X1000 Y1000 Z250 E5000 ; Set accelerations (mm/s^2)
                          M906 X1200 Y1200 Z1500 E1300 I30 ; Set motor currents (mA) and motor idle factor in per cent
                          M84 S30 ; Set idle timeout
                          M572 D0 S0.15 ; Pressure Advance                                        ; Set idle timeout
                          M208 X-7 Y-22 Z0 S1                                 ; set axis minima
                          M208 X312 Y331 Z300 S0                           ; set axis maxima
                          M574 X1 S1 P"xstop"   ; X min active high endstop switch
                          M574 Y1 S1 P"ystop"   ; Y min active high endstop switch
                          G31 P500 X0 Y-40 Z2.65 		; Z probe trigger offset, high Z number closer means to bed (LARGER Z MEANS CLOSER BED)
                          M308 S0 P"bedtemp" Y"thermistor" T100000 B4138   ; configure sensor 0 as thermistor on pin bedtemp
                          M950 H0 C"bedheat" T0                            ; create bed heater output on bedheat and map it to sensor 0
                          M140 H0											; Map heated bed to heater 0
                          M143 H0 S120                                     ; set temperature limit for heater 0 to 120C
                          M307 H0 A61.9 C160.5 D1.3 B0 S0.5 v24.4          ; disable bang-bang mode for the nozzle heater and set PWM limit
                          M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
                          M950 H1 C"e0heat" T1                             ; create nozzle heater output on e0heat and map it to sensor 1
                          M143 H1 S285; set temperature limit for heater 1 to 280C
                          M307 H1 A310.2 C150.5 D3.5 B0 S1 v24.3		;NEW
                          ;M307 H1 A493 C243 D3.9 B0 S0.9 v24.3          ; disable bang-bang mode for the nozzle heater and set PWM limit
                          M950 F0 C"fan0" Q500                             ; create fan 0 on pin fan0 and set its frequency
                          M106 P0 S0 H-1                                   ; set fan 0 value. Thermostatic control is turned off
                          M950 F1 C"fan1" Q500                             ; create fan 1 on pin fan1 and set its frequency
                          M106 P1 S1 H1 T45                                ; set fan 1 value. Thermostatic control is turned on
                          M950 F2 C"fan1" Q500                             ; create fan 2 on pin fan1 and set its frequency
                          M106 P2 S1 H1 T45                                ; set fan 2 value. Thermostatic control is turned on
                          M563 P0 D0 H1 F0                                 ; define tool 0
                          G10 P0 X0 Y0 Z0                                  ; set tool 0 axis offsets
                          G10 P0 R0 S0                                     ; set initial tool 0 active and standby temperatures to 0C
                            Adamfilip
                              Is this a Duet IR sensor or a clone? Was it purchased recently?
                                Adamfilip
                                its a Duet sensor.. not clone. purchased 4 months ago
                                  Adamfilip
                                  I reduced the trigger value from 500 down to 400 and it seems to be working again. before updating firmware it worked fine at 500
                                    Phaedrux Moderator @Adamfilip
                                    Is it working better now?
                                      Adamfilip
                                      no, I spoke too soon!
                                      It does trigger more consistently but its all over the place now
                                      probing.JPG l)
                                        Adamfilip
                                        Should i use M558 P2 instead of P1?
                                          Adamfilip
                                          I ran a Mesh compensation sequence and I noticed that when it was probing. While watching the Z probe values.. sometimes the Probe value was around 100 between probings and other times it was zero.. makes me wonder if there is a wire issue
                                            What's your wiring like? Photo? Is it running alongside anything else?
