    Warning: the height map has a substantial Z offset
    946
    • downshift64
      downshift64 last edited by
      7/18/2020, 9:07:34 AM M98 P"0:/macros/PROBE BED GRID"
      Warning: the height map has a substantial Z offset. Suggest use Z-probe to establish Z=0 datum, then re-probe the mesh.
      256 points probed, min error -0.035, max error 0.396, mean 0.189, deviation 0.086
      Height map saved to file heightmap.csv
      where do i start in fixing this so i dont get this warning and make sure it is using my hieghtmap mesh
      • fcwilt
        fcwilt last edited by
        Are you doing a G30 to set the Z=0 datum?
        Printers: A FT-5 with the 713 upgrade bits, a custom MarkForged style, a small Utilmaker style, a small CoreXY from kit and a E3D MS/TC setup. Various hotends. Using Duets (2 and 3) running 3.4.6
        • downshift64
          sorry i dont know what that means
          • downshift64
            @fcwilt said in Warning: the height map has a substantial Z offset:
            this is a new thing with my 3D printer worked fine up untill i tried to update it then that didnt go well so i went back to an older version worked fine for awhile then this warning started to pop up
            fcwilt 1 Reply Last reply Reply Quote 0
            • fcwilt
              fcwilt @downshift64 last edited by
              @downshift64 said in Warning: the height map has a substantial Z offset:
              Well the warning occurs when the Z offset exceeds a certain amount. So that suggests something has changed as you have used the printer.
              The warning mentioned setting the Z=0 datum and that is what a G30 command does.
              "G30 ; Probe the bed at the current XY position. When the probe is triggered, set the Z coordinate to the probe trigger height.
              You normally would do a G30 before doing a G29 to probe the bed to create the height map.
              You also would do a G30 before doing a G29 S1 command which loads the previously created height map.
              What action do you take to create the height map?
              • downshift64
                i calibrate my z probe height enter that in the config.g file under G31 then probe bed grid it saves the heightmap then thats it iam done
                • fcwilt
                  Well include the G30 in the two places I mentioned and see if you get better results.
                  • downshift64
                    include it where
                    • downshift64
                      config.g
                      • downshift64
                        ; Configuration file for EMW ULTIMATE XL. RTFM! https://duet3d.dozuki.com/
                        M111 S0 ; Debug off
                        M550 PULTIMATE XL ; Machine name and Netbios name (can be anything you like, PREFIX WITH CAPITAL P)
                        M551 Preprap ; Machine password (used for FTP)
                        ;*** NETWORKING
                        M552 S1 ; Turn network on
                        M555 P2 ; Set output to look like Marlin
                        G21 ; Work in millimetres
                        ; DRIVES
                        M584 X0 Y1:4 Z2 E3 ; DRIVE MAPPING. EXAMPLE: X0 IS X AXIS MAPPED TO DRIVE 0
                        M569 P0 S0 ; DRIVE 0 DIRECTION. X AXIS S1 OR S0 FOR DIRECTION
                        M569 P1 S1 ; DRIVE 1 DIRECTION. Y AXIS M1 S1 OR S0 FOR DIRECTION
                        M569 P2 S0 ; DRIVE 2 DIRECTION. Z AXIS S1 OR S0 FOR DIRECTION
                        M569 P3 S1 ; DRIVE 3 DIRECTION. EXTRUDER S1 OR S0 FOR DIRECTION
                        M569 P4 S1 ; DRIVE 4 DIRECTION. Y AXIS M2 S1 OR S0 FOR DIRECTION
                        M350 X16 Y16 Z16 E16 I1 ;M350 MICROS STEPPING
                        M92 X200 Y200 Z400 E409 ;M92 SET STEPS PER MM
                        M201 X2500 Y2500 Z2500 E2500 ;M201 ACCEL MM/S
                        M203 X20000 Y20000 Z3500 E5000 ;M203 MAXIMUM SPEEDS MM/M
                        M566 X700 Y700 Z500 E800 ;M566 JERK MM/S
                        M906 X1900 Y1600:1600 Z1400 E1100 I30 ;M906 SET MOTOR CURRENT IN mA. I VALUE IS IDLE CURRENT PERCENT
                        M84 S30 ;M84 MOTOR CURRENT IDLE TIMEOUT IN SECONDS.
                        ; AXIS LIMITS
                        M208 X-27 Y-22 Z-3.0 S1 ; SET MIN TRAVEL
                        M208 X295 Y295 Z298.85 S0 ; SET MAX TRAVEL. Z MAX VALUE DURING INTIAL CALIBRATION IS TUNED HERE
                        ; ENDSTOPS
                        M574 X1 Y1 S1 ; SET ACTUVE LOW ENDSTOPS
                        M574 Z2 S1 ; SET ACTIVE HIGH ENDSTOPS
                        ; LINEAR ADVANCE
                        M572 D0 S0.03
                        ; Z PROBE
                        M557 X0:290 Y0:290 S19.333 ; M557 SET PROBE GRID AND SPACING
                        M558 P4 F300 H2 I1 T10000 A4 S0.01 R0.8 X0 Y0 Z ; Z probe is presicion touch porbe, normaly open
                        G31 X0 Y0 Z69.92 P5 ; G31 SET Z PROBE OFFSETS. ADJUST THIS Z VALUE PER CALIBRATING PROBE HEIGHT MACRO
                        ; PROBE COMPENSATION TAPER.
                        ;M376 H10 ; TAPER HEIGHT FOR GRID COMPENSATION. SLOWLT TAPER COMPENSTION UP TO SET HEIGHT. ONCE AT HEIGHT COMPENSATION WILL NOT BE IN EFFECT. DISABLED BY DEFAULT (EMW ULXL)
                        ; TEMPERATURE SENSOR PARAMETERS
                        M305 P0 T100000 B3950 R4700 H0 L0 ; BED SENSOR IS 100K THERMISTOR WITH BETA VALUE OF 3950. DUET WIFI INLINE RESISTOR 4700
                        M305 P1 T100000 B4725 C0.0000000706 R4700 H0 L0 ; HOT END SENSOR IS 100K THERMISTOR WITH BETA VALUE OF 4725. DUET WIFI INLINE RESISTOR 4700. C VALUE IS COMPENSATION VALUE AT HIGHER TEMPS.
                        ; HEATER TUNING PID
                        • downshift64
                          ; HEATER TUNING PID
                          M307 H0 A522.8 C1351.1 D19.3 B0 ;H0 IS HEAT BED. AUTOTUNED NOV. 2019 EMW ULXL
                          M307 H1 A408.1 C196.0 D4.6 B0 ;AUTOTUNED RESULTS STOCK E3D HEMERA
                          ;HEATER SAFETY
                          M143 H0 S105 A1
                          M143 H1 S305 A1
                          ; FANS
                          M106 P0 S-1 L0.2 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                          M106 P1 S1.0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                          M106 P2 H100:101 T35:45 L0.6
                          M563 P0 D0 H1 ; Define tool 0
                          T0
                          ; POWER FAILURE RECOVERY. EMW ULXL REQUIRES SEPERATE MODULE TO WORK. PLEASE CONTACT ELITE MACHINE WORKS FOR DETAILS.
                          M911 S23.5 R23.9 P"M913 X0 Y0 G91 M83 G1 Z3 E-1 F1000"
                          ; Custom settings
                          M581 E0:1 S0 T1 C1
                          M581 E0:1 S0 T0 C1
                          ; BED HEATER RELAY ACTIVATION WHEN POWERING ON OR REBOOTING PRINTER.
                          M80 ; TURN BED HEATER RELAY ON
                          • fcwilt
                            fcwilt @downshift64 last edited by fcwilt
                            include it where
                            Well I have a macro that I execute to create the height map so the G30 and G29 go there along with any other commands needed. My macro file doesn't actually look like this as I have included the contents of a few other macros into this code.
                            ; ----- configure z probe -----
                            M307 H7 A-1 C-1 D-1				; step 1 - disable E6 heater to enable PWM5
                            M558 P9 H2 F600 T12000 A5 S0.01 R0.2	        ; step 2 - set probe configuration - part 1
                            G31 X0 Y24.5 Z1.525 P25			        ; step 3 - set probe configuration - part 2
                            M280 P7 S160					; clear BLTouch alarm (if any)
                            ; ----- set Z=0 datum using probe ----
                            G29 S2						; cancel mesh bed compensation
                            M290 R0 S0 					; cancel baby stepping
                            G90						; absolute moves
                            G1 Z10 F600					; position on Z for probing
                            G1 X0 Y-25                                      ; position on XY for probing
                            G30						; do single probe - sets Z to probe trigger height
                            ; ---- create height map -----
                            M208 Y-155:145				        ; adjust axis min/max values as needed to allow for Z probe offset
                            M557 X-130:130 Y-130:130 S20:20	                ; define mesh for G29
                            G29						; do probing and create height map file
                            M208 Y-145:145		                        ; reset axis min/max values
                            G1 Z5 F600					; move nozzle away from bed
                            • fcwilt
                              I also have a macro for loading the height map. The macro I have for starting a print invokes this file.
                              Notice here that I am showing the invoking of the macros for configuring the probe and setting the Z=0 datum.
                              The code that performs these function, that I included the previous post, is essentially what is in these two macros.
                              M98 P"configprobe.g"		; configure Z probe
                              M98 P"probeZ.g"			; set Z=0 Datum
                              G29 S1                          ; load height map
                              M376 H10		        ; set bed compensation taper
                              • downshift64
                                thank you i will give them a try does it matter where i put these commands in the config.g
                                • downshift64
                                  i dont use a BLTouch i attach a probe then when i am done take it off and usually dont use it again unless something changes
                                  • fcwilt
                                    They should NOT be part of config.g.
                                    If you do like I do and create the height map manually by invoking the macro you would create a macro to do that.
                                    If you wish to create the height map on every print you should invoke the code when starting a print.
                                    As to loading the height map it should be part of the code you invoke when starting a print.
                                    I have my slicer invoke a macro called "print_begin.g". All of the code needed to prepare for printing is in that macro.
                                    Also In this macro I invoke the macro to load the height map.
                                    • downshift64
                                      damn i wish this was easier
                                      • fcwilt
                                        Hmm...
                                        Then I don't know how you are going to set the Z=0 datum without a Z probe.
                                        I have found that I needed to install a BLTouch as the Z=0 setting changed as the bed assembly heated up. So each print potentially needed to have Z=0 set again - which is what I do now.
                                        • downshift64
                                          i heat the bed up then probe it and save the height map i have something that uses that each time i start a new print
                                          • fcwilt
                                            If you have a Z probe AND make use of macros called via M98 it can be fairly straightforward and easy to maintain.
                                            • downshift64
                                              my slicer start g code
                                              G90 ; use absolute coordinates
                                              M83 ; extruder relative mode
                                              M104 S[first_layer_temperature] T0 ; set extruder temp
                                              M140 S[first_layer_bed_temperature] ; set bed temp
                                              M190 S[first_layer_bed_temperature] ; wait for bed temp
                                              M109 S[first_layer_temperature] T0; wait for extruder temp
                                              G28 ; home all without mesh bed level
                                              G29 S1 ; mesh bed leveling
                                              G1 Z0.25 F2500
                                              G1 Y0 F1000.0 ; go outside print area
                                              G92 E0.0
                                              G1 X60.0 E9.0 F1000.0 ; intro line
                                              G1 X100.0 E12.5 F1000.0 ; intro line
                                              G92 E0.0
                                              M221 S{if layer_height<0.075}100{else}95{endif}
                                              • fcwilt
                                                The problem is the height map is referenced to the Z=0 datum when the height map is created.
                                                When the height map is loaded it expects that Z=0 datum to be the same value.
                                                Without a Z probe I'm not sure how to handle it other than assuming Z=0 is a fixed value and never changes.
                                                • downshift64
                                                  ya once i get height map it is a fixed value and should never change really
                                                  • fcwilt
                                                    That has not been my experience with my printers but if yours is unchanging that is great.
                                                    • downshift64
                                                      its an Ulitmate XL from Elite Machine Works its a solid bed
