    Change ATX OFF button
    Firmware installation
    • matej1006undefined
      matej1006
      I would like to change ATX OFF code that instead of turn printer off goes to Z max and goes to off
      • A Former User?
        A Former User
        If you're referring to a hardwired button, then just add G1 Zn to the macro.
        If referring to DuetWebControl it'll require a change to the code. The smooth approach would probably be to change the firmware execute atxoff.g and atxon.g if they exist, as it would also work with just sending the g-code and not just though DuetWebControl
        Workaround would be to create a macro and run that, but a little less accessible.
          matej1006
          Where can i find this two macros
          • A Former User?
            A Former User
            to expand on https://forum.duet3d.com/post/166154
            hack the code
            https://github.com/Duet3D/RepRapFirmware/
              matej1006
              do i have that reprap or DWC code?
              in reprap i didn't found any m81 or atxpower section
