How to determine if a filament is selected for a tool
I would like to write some conditional code based a filament selection having been loaded into a given tool.
Is it possible?
Thanks.
@fcwilt I also was looking for this, I figured it would be in the metadata somewhere but could not find it.
My workaround solution was to have the user select a filament - then based on that selection, write a separate macro file, with the contents of gcode to be executed for that filament type.This is not what you were asking for, but it may give you an idea to conquer your objective. I made three macro files that work as a team, look at "Set Filament Type" macro:
Filament Handling
; 0:/macros/Filament Handling ; Macro used for all filament handling evolutions if state.status != "processing" ; Printer is not currently printing! if sensors.filamentMonitors[0].filamentPresent = true M291 P"Press OK to begin filament UNLOADING, else press CANCEL to exit." R"Filament Handling" S3 M291 P"Please wait while the nozzle is being heated." T5 ; Display message M98 P"0:/macros/Heat Nozzle" ; heat nozzle to predetermined temp M291 P"Ready for filament unloading. Gently pull filament and press OK." R"Filament Handling" S2 M291 P"Retracting filament..." T5 ; Display another message G1 E-150 F5000 ; Retract filament M400 ; Wait for the moves to finish T0 M702 ; Select tool 0, set filament to NOT LOADED M104 S-273 ; turn off temperature M140 S-273 ; turn off heatbed M98 P"0:/macros/Filament Handling"; run again else M291 P"Press OK to begin filament LOADING, else press CANCEL to exit." R"Filament Handling" S3 M291 P"Please wait while the nozzle is being heated." T5 ; Display message M98 P"0:/macros/Heat Nozzle" ; heat nozzle to predetermined temp M291 P"Ready for filament loading. Insert filament and press OK." R"Filament Handling" S2 M291 P"Feeding filament..." T5 ; Display new message G1 E150 F450 ; Feed 150mm of filament at 600mm/min G1 E20 F100 ; Feed 20mm of filament at 100mm/min G4 P1000 ; Wait one second G1 E-1 F1800 ; Retract 10mm of filament at 1800mm/min M400 ; Wait for moves to complete M98 P"0:/sys/filaset" ; set filament type and LOADED M400 ; Wait for moves to complete M104 S-273 ; turn off temperature M140 S-273 ; turn off heatbed else M291 P"Press OK to begin filament CHANGE, else press CANCEL to exit." R"Filament Handling" S3 M98 P"0:/sys/filament-change.g" ; call filament-change.g M24
Heat Nozzle
; 0:/macros/Heat Nozzle ; Macro used to heat hozzle to temperture set by "Set Filament Type" macro M291 R"Filament Handling" P"Heating nozzle for PETg, please wait." S0 T5 T0 M109 S230 ; set temp to 230c and wait
Set Filament Type
; 0:/macros/Set Filament Type ; Macro used to set system's loaded filament type if sensors.filamentMonitors[0].filamentPresent = false ; if filament is loaded then reject action to change filament type M291 P"Press OK to change filament type, else press CANCEL to exit." R"Filament Handling" S3 ; Set PLA temp M28 "0:/macros/Heat Nozzle" ; Begin writing to SD card file M291 R"Filament Handling" P"Heating nozzle for PLA, please wait." S0 T5 T0 ; Activate Hotend M109 S200 ; set temp to 200c and wait M29 ; Stop writing to SD card M28 "0:/sys/filaset" ; Begin writing to SD card file ; This gcode is used by Filament Handling Macro T0 M702 ; Set system filament as UNLOADED T0 M701 S"PLA" ; Set system filament as PLA M29 ; Stop writing to SD card M291 S3 R"Filament Handling" P"Filament type currently set to PLA. Press cancel to save this selection or OK to proceed to next filament type." ; Set PETg temp M28 "0:/macros/Heat Nozzle" ; Begin writing to SD card file M291 R"Filament Handling" P"Heating nozzle for PETg, please wait." S0 T5 T0 ; Activate Hotend M109 S230 ; set temp to 230c and wait M29 ; Stop writing to SD card M28 "0:/sys/filaset" ; Begin writing to SD card file ; This gcode is used by Filament Handling Macro T0 M702 ; Set system filament as UNLOADED T0 M701 S"PETG" ; Set system filament as PETG M29 ; Stop writing to SD card M291 S3 R"Filament Handling" P"Filament type currently set to PETg. Press cancel to save this selection or OK to proceed to next filament type." ; Set ABS temp M28 "0:/macros/Heat Nozzle" ; Begin writing to SD card file M291 R"Filament Handling" P"Heating nozzle for ABS, please wait." S0 T5 T0 ; Activate Hotend M109 S250 ; set temp to 250c and wait M29 ; Stop writing to SD card M28 "0:/sys/filaset" ; Begin writing to SD card file ; This gcode is used by Filament Handling Macro T0 M702 ; Set system filament as UNLOADED T0 M701 S"ABS" ; Set system filament as ABS M29 ; Stop writing to SD card M291 S3 R"Filament Handling" P"Filament type currently set to ABS. Press cancel to save this selection or OK to proceed to next filament type." ; Set PC temp M28 "0:/macros/Heat Nozzle" ; Begin writing to SD card file M291 R"Filament Handling" P"Heating nozzle for PC, please wait." S0 T5 T0 ; Activate Hotend M109 S270 ; set temp to 270c and wait M29 ; Stop writing to SD card M28 "0:/sys/filaset" ; Begin writing to SD card file ; This gcode is used by Filament Handling Macro T0 M702 ; Set system filament as UNLOADED T0 M701 S"PC" ; Set system filament as PC M29 ; Stop writing to SD card M291 S3 R"Filament Handling" P"Filament type currently set to PC. Press cancel to save this selection or OK to proceed to next filament type." else M291 S3 R"Filament Handling" P"Filament is currently loaded. Please unload filament before changing filament type."
I could be wrong, but I think the filament stuff is located within DWC only, so probably not in the object model.
@chrishamm would have to give more detail.
Does OM field move.extruders[n].filament have the information you are looking for?
@dc42 said in How to determine if a filament is selected for a tool:
Yes that is what I was looking for. Just wasn't able to find it.
Thanks much.
@dc42, could you help me with the following please.
This line works:
echo "System filament currently set to: " ^ move.extruders[0].filament ^ "."
This one, not so much:
M291 P"System filament currently set to: " ^ move.extruders[0].filament ^ ". Press OK to change filament type, else press CANCEL to exit." R"Filament Handling" S3
Cheers,
Kolbi
This works:
M291 P{move.extruders[0].filament} ^ " is currently set. Press OK to change filament type, else press CANCEL to exit." R"Filament Handling" S3
That's almost correct. When you use an expression as the value of a parameter in a regular G- or M-code command, you must enclose it in { }. See https://duet3d.dozuki.com/Wiki/GCode_Meta_Commands#Section_Use_of_expressions_within_GCode_commands. So it should really be:
M291 P{move.extruders[0].filament ^ " is currently set. Press OK to change filament type, else press CANCEL to exit."} R"Filament Handling" S3
@dc42 Thanks!
