Need Help with Configuration Files
  • I just uploaded some configuration files onto the Duet Wifi courtesy of another user that has the same printer. While it was uploading via the web interface, the server crashed. I was unable to access it through wifi and pronterface. I suspect it has to do with one of the files that I uploaded. I then proceeded to reset the firmware through sam-ba and was successful in doing so. Afterwards, there were no problems connecting to pronterface and no problems invoking M503 to check on the config file. The problem arises when I invoke M552 S1. It says wifi starting, but hangs pronterface. I let it run for a few minutes and it still does not work. As mentioned above, this happened when I uploaded an entire sys folder into the board. Anyone have the stock configurations of the sd card so that I can effectively get a stock "new" board? Thanks
  • Have you followed the step by step guide?
    https://duet3d.com/wiki/Getting_connected_to_the_Duet_WiFi
    I suggest you copy the correct DuetWiFiserver-xxx.bin file to the SD card on a PC, then put the SD card back in the Duet, start the Duet, and send M997 S1 to re-flash the wifi module.
    If you have flashed version 1.18.2 or earlier firmware, you need DuetWiFiServer-1.03ch.bin. if you have flashed version 1.19beta6 then you need DuetWiFiServer-1.19beta1.bin.
