Speed issue: Web-Interface vs. Telnet
  • Hi all,
    I have an interesting problem with the Duet2.
    I want to slowly move the z-axis down and then call a macro. The macro moves the Y axis back and forth several times very fast.
    In my sequence I communicate with the Duet board via Telnet. If I call the macro after I slowly move down, the Y axis will also move slowly, although the speed is set in the macro.
    If I call the macro from the web interface, it works.
    If I call the macro via Telnet again, it will move slowly again.
    What is the reason for this? Are there two different speeds for Telnet and HTTP?
    Many thanks.
    Jonzy
  • iirc someone did some testing to find telnet faster, which makes sense as it has less (none) overhead; but telnet is also something that is likely to be deprecated in the future.
    if you try to dig through some search results here you might find the posts
    Please share the contents of the macro. There should be no difference in the behaviour.
