    run a mesh compensation in work coordinates?
    CNC
    • window_lickerundefined
      window_licker
      Hi!
      I use Duet 2 Wifi in a small CNC machine to mill PCBs, in order to compensate for board uneven height I use a mesh compensation. Z-endstop is configured as a normally open contact between the PCB copper layer and a carving bit.
      Now the procedure looks like this:
      • I put the PCB board in place
      • Switch the machine to absolute coordinates (G54)
      • Set up the PCB size (M557 X12.5:42.5 Y50:75.5 S10, note: absolute coordinates),
      • Z-home the carving bit to the surface of the PCB and set global z=0
      • Run grid compensation (G29), produce a mesh compensation file so I can load it in gcode file afterward with G29 S1.
      • Switch to work coordinates (G55)
      • Home everything again, this time in local coordinates, to set a work zero properly
      • Start milling
      I'm wondering is it possible to somehow shave some of these steps? Like, being able to set M557 in local (work) coordinates and successfully run a G29 etc?
      Ideally I would see the process like this:
      • Put the board in place
      • Jog to the side of the board, set work coordinates x=0, y=0
      • Z-home the carving bit to the surface setting work z=0
      • Inform firmware about the size of the board using something like M557 X0:10 Y0:20 S10
      • Run G29
      • Start carving using G29 S1 at the beginning of the g-code
      Mito Kafanderundefined 1 Reply Last reply Reply Quote 0
      • Mito Kafanderundefined
        Mito Kafander @window_licker
        @window_licker also interested in a more streamline process for this procedure. I have a cnc and I'd use this to carve onto uneven surfaces that are not associated with the curvature of the bed.
