    RRF 3.1.1 move.axes[0].userPosition=move.axes[0].userPosition/2
    Gcode meta commands
    • rziundefined
      rzi
      I'm trying to make a hole probe macro with RRF 3.1.1
      Is it possible to read current axis work position and divide it by 2?
      The below does not work: move.axes[0].userPosition=move.axes[0].userPosition/2
      but is it possible to achieve this in some other way?
      ::Rickard::
      • NexxCatundefined
        NexxCat
        Wouldn't you just need to do the following?
        G0 X{move.axes[0].userPosition/2}
        • rziundefined
          rzi
          Thanx! woprks very well now. This is what I ended up with.
          M558 K0 P5 C"!io2.in" F100; create probe #1 for use with M585, active low
          G38.2 X596 P0
          G10 P2 L20 X0
          G0 X{move.axes[0].userPosition-1}
          G38.2 X0 P0
          G10 P2 L20 X0
          G38.2 y810 P0
          G10 P2 L20 Y0
          G0 Y{move.axes[0].userPosition-1}
          G38.2 Y0 P0
          G0 Y{move.axes[1].userPosition/2}
          G10 P2 L20 Y0
