    Heat bed lost
    Firmware installation
    1
    • schtiundefined
      schti
      Hi guys
      just have upgraded duetwifi board from 3.0 to 3.11 and have realized that the heat bed disappeared
      M111 S0 ; Debugging off
      G21 ; Work in millimetres
      M555 P1 ; Set firmware compatibility to look like RepRapFirmare
      M665 R157 L398 B175 H525 ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them
      M208 Z0 S1 ; Set minimum Z
      M574 X2 S1 P"xstop" ; X high active high endstop switch
      M574 Y2 S1 P"ystop" ; Y high active high endstop switch
      M574 Z2 S1 P"zstop" ; Z high active high endstop switch
      ; BL-Touch
      M558 P9 X0 Y0 Z0 H3 F100 T5000 ; Set Z probe type to unmodulated and the dive height + speeds
      M307 H3 A-1 C-1 D-1 ; reserve Heater 3 Pin for M42 or servo use
      M558 P9 C"^zprobe.in" H3 F100 T5000 ; BLTouch connected to Z probe IN pin
      M950 S0 C"exp.heater3" ; create servo/gpio 0 on heater 3 pin on expansion connector
      ;M280 P0 S10 ; send control signal to BLTouch through servo/gpio 0
      ; Offset depending on nozzle size
      G31 P25 X0 Y-21 Z2.66 ; Set Z probe trigger value, offset and trigger height for 0.4mm Nozzle
      ;G31 P25 X0 Y-21 Z1.208 ; Set Z probe trigger value, offset and trigger height for 0.6mm Nozzle
      M557 R150 S15 ; mesh grid
      M584 X0 Y1 Z2 E3
      M350 E32 I0 ; Configure microstepping without interpolation
      M350 X32 Y32 Z32 I1 ; Configure microstepping with interpolation
      M92 X160 Y160 Z160 E1607.45 ; Set steps per mm
      M566 X1200 Y1200 Z1200 E3000 ; Set maximum instantaneous speed changes (mm/min)
      M203 X39960 Y39960 Z39960 E3000 ; Set maximum speeds (mm/min)
      M201 X1000 Y1000 Z1000 E1500 ; Set accelerations (mm/s^2)
      M906 X1800 Y1800 Z1800 E1500 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M143 S285 ; Set maximum heater temperature to 285C
      M308 S0 P"bed_temp" Y"thermistor" T100000 B4607 C8.950070e-8 R4700 ; Set thermistor + ADC parameters for heater 0
      M308 S1 P"e0_temp" Y"thermistor" T100000 B4607 C8.950070e-8 R4700 ; Set thermistor + ADC parameters for heater 0
      ;M308 S1 P"spi.cs1" Y"rtd-max31865" ; create sensor number 1 as a PT100 sensor in the first position on the Duet 2 daughter board connector
      M950 H0 C"bed_heat" T0 ; heater 0 uses the bed_heat pin, sensor 0
      M950 H1 C"e0_heat" T1 ; heater 0 uses the bed_heat pin, sensor 0
      M301 H0 S1.00 P10 I0.1 D200 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
      M563 P0 D0 H1 ; Define tool 0
      where to dig?
      Thanx in advance
      • schtiundefined
        schti
        Solved
        Forgot to add M140 H0
