Updated to V3, now nothing works!
  • Warning, I'm a noob. My config can be seen below. I went through the reprap configuration tool to generate this and I am not sure if I have my stepper motors correct. The icon I would press on my duet panel for my hotend is missing, also?
    Rig is:
    Folgertech FT-6 with standard kit (this has the heated bed, plugged into bedheat and bedtemp)
    Duet Wifi 2 (No duex)
    E3D V6 hotend (plugged into e0 temp and e0 heat)
    Any and all help is appreciated, I am still learning quite a bit!
    Edit: If it's just all sorts of messed up, the hubby has been revising it to try and figure out the issue. This is like... iteration #20.
    Edit edit: Heaters are working now!
    ; generated by RepRapFirmware Configuration Tool v3.1.4 on Fri Sep 04 2020 17:09:43 GMT-0500 (Central Daylight Time)
    G90                                      ; send absolute coordinates...
    M83                                      ; ...but relative extruder moves
    M550 P"Folgertech T6"                    ; set printer name
    M551 P"zzzzzzzz"                         ; set password
    M552 S1                                  ; enable network
    M586 P0 S1                               ; enable HTTP
    M586 P1 S0                               ; disable FTP
    M586 P2 S0                               ; disable Telnet
    M569 P0 S0                               ; physical drive 0 goes backwards
    M569 P1 S1                               ; physical drive 1 goes forwards
    M569 P2 S0                               ; physical drive 2 goes backwards
    M569 P3 S0                               ; physical drive 3 goes backwards
    M584 X0 Y1 Z2 E3                         ; set drive mapping
    M350 X16 Y16 Z16 E16 I1                  ; configure microstepping with interpolation
    M92 X80.00 Y80.00 Z721.92 E88.32         ; set steps per mm
    M566 X900.00 Y900.00 Z12.00 E120.00      ; set maximum instantaneous speed changes (mm/min)
    M203 X6000.00 Y6000.00 Z180.00 E1200.00  ; set maximum speeds (mm/min)
    M201 X500.00 Y500.00 Z20.00 E250.00      ; set accelerations (mm/s^2)
    M906 X1500 Y1500 Z1500 E1500 I30         ; set motor currents (mA) and motor idle factor in per cent
    M84 S30                                  ; Set idle timeout
    M208 X0 Y0 Z0 S1                         ; set axis minima
    M208 X670 Y320 Z384 S0                   ; set axis maxima
    M574 X2 Y2 S1                            ; set active high endstops
    M574 Z2 S2                               ; set endstops controlled by probe
    M307 H4 A-1 C-1 D-1                      ; disable heater on PWM channel for BLTouch
    M558 P9 H5 F120 T6000                    ; set Z probe type to bltouch and the dive height + speeds
    G31 P500 X0 Y0 Z1.089                    ; set Z probe trigger value, offset and trigger height
    M557 X20:670 Y20:320 S200                ; define mesh grid
    M305 P0 T100000 B3950 R4700              ; set thermistor + ADC parameters for heater 0
    M143 H0 S120                             ; set temperature limit for heater 0 to 120C
    M305 P1 T100000 B4725 C7.060000e-8 R4700 ; set thermistor + ADC parameters for heater 1
    M143 H1 S280                             ; set temperature limit for heater 1 to 280C
    M106 P0 S0 I0 F500 H-1                   ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M106 P1 S1 I0 F500 H-1                   ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M563 P1 H1 F-1                           ; define tool 1
    G10 P1 X0 Y0 Z0                          ; set tool 1 axis offsets
    G10 P1 R0 S0                             ; set initial tool 1 active and standby temperatures to 0C
  • Moderator
    Well that config is for RRF2, not 3.
    Send M115 to see what firmware you actually have installed.
    You should update from 2.05.1 to 3.0 to 3.1.1
    Easiest way to update is to upload the entire firmware zip file in DWC and it will take care of the rest.
    https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
    https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/Duet2and3Firmware-3.1.1.zip
    In the config tool make sure you select firmware version 3+
  • Thank you for the response, Phaedrux! I did as you said. I'm currently running 3.1.1, my updated config is below. The problem we develop is with the heaters. Going through the configurator, we set the heaters up to match where they are plugged in on the board, but when we do this is what happens:
    The bed temps disappear, and they are also faulting, with temp readings at 2000C.
    We have tried every combination possible to fix it and we can't. I didn't realize it at the time, but my hubby reverted us back to the v2 to get them to work (even though we are running 3.1.1).
    We are also having problems with our BLTouch/Homing (Shocking!). I've popped that code in too.
    This is our config file as it is currently.
    ; generated by RepRapFirmware Configuration Tool v3.1.4 on Fri Sep 04 2020 22:24:11 GMT-0500 (Central Daylight Time)
    M550 P"Folgertech FT6"                                 ; set printer name
    M574 X1 S1 P"xstop"                                    ; configure active-high endstop for low end on X via pin xstop
    M574 Y1 S1 P"ystop"                                    ; configure active-high endstop for low end on Y via pin ystop
    M574 Z1 S2                                             ; configure Z-probe endstop for low end on Z
    M950 S0 C"exp.heater7"                                 ; create servo pin 0 for BLTouch
    M558 P9 C"^zprobe.in" H5 F120 T6000                    ; set Z probe type to bltouch and the dive height + speeds
    G31 P500 X8 Y22 Z1.089                                 ; set Z probe trigger value, offset and trigger height
    M308 S0 P"e0temp" Y"thermistor" T100000 B3950          ; configure sensor 0 as thermistor on pin e0temp
    M950 H0 C"e0heat" T0                                   ; create bed heater output on e0heat and map it to sensor 0
    M307 H0 B1 S1.00                                       ; enable bang-bang mode for the bed heater and set PWM limit
    M140 H0                                                ; map heated bed to heater 0
    M308 S1 P"e1temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e1temp
    M950 H1 C"e1heat" T1                                   ; create nozzle heater output on e1heat and map it to sensor 1
    M307 H1 B0 S1.00                                       ; disable bang-bang mode for heater  and set PWM limit
    M950 F0 C"fan0" Q500                                   ; create fan 0 on pin fan0 and set its frequency
    M106 P0 S0 H-1                                         ; set fan 0 value. Thermostatic control is turned off
    M950 F1 C"fan1" Q500                                   ; create fan 1 on pin fan1 and set its frequency
    M106 P1 S1 H-1                                         ; set fan 1 value. Thermostatic control is turned off
    M563 P0 S"Nozzle" D0 H1 F-1                            ; define tool 0
    G10 P0 X0 Y0 Z0                                        ; set tool 0 axis offsets
    G10 P0 R0 S0                                           ; set initial tool 0 active and standby temperatures to 0C
    M575 P1 S1 B57600                                      ; enable support for PanelDue
    Homeall
    ; homeall.g
    ; called to home all axes
    G1 H2 Z5 F6000          ; lift Z relative to current position
    G1 H1 X-725 Y-355 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
    G1 H2 X5 Y5 F6000       ; go back a few mm
    G1 H1 X-725 Y-355 F360  ; move slowly to X and Y axis endstops once more (second pass)
    G1 X350 Y150 F6000        ; go to first bed probe point and home Z
    G30                     ; home Z by probing the bed
    Thank you so so so much for having a look, we've been beating our heads against a wall for a week 😞 I'm still learning how to manipulate gcode and with the update to 3.1.1 I feel like I've fallen massively behind.
    Are you certain that you are running RRF 3.1.1? Send M115 to check.
    Also send M98 P"config.g" to see if there are any error messages from commands in config.g.
  • alt text
    I am not sure of anything anymore lol.
  • you only updated the web ui.
    you first have to upgrade to 3.0 then to 3.1.1
    see
  • you're running RRF 2.04 now, and probably tried upgrading to RRF3?
    you'll need to upgrade in a few steps, covered in
    https://github.com/Duet3D/RepRapFirmware/blob/v3-dev/WHATS_NEW_RRF3.md#reprapfirmware-311
    most notably 3.0.0 before 3.1.1
  • Moderator
    @Phaedrux said in Updated to V3, now nothing works!:
  • I did it again, it's moving up to 3.1.1 but it's been saying "please wait for the updates to be installed" for about 10 mins. The console on the paneldue says "Error: Failed to add SSID to remembered list"
  • Moderator
    Can you post your current config?
    If you're connected by usb terminal can you post the results of m122?
  • === Diagnostics ===<LF>RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later<LF>Board ID: 08DGM-917DA-G4MSJ-6J9FG-3S46K-1SP3B<LF>Used output buffers: 1 of 24 (2 max)<LF>=== RTOS ===<LF>Static ram: 27980<LF>Dynamic ram: 93692 of which 20 recycled<LF>Exception stack ram used: 256<LF>Never used ram: 9124<LF>Tasks: NETWORK(ready,1892) HEAT(blocked,1224) MAIN(running,1912) IDLE(ready,80)<LF>Owned mutexes:<LF>=== Platform ===<LF>Last reset 00:01:31 ago, cause: power up<LF>Last software reset at 2020-09-05 05:43, reason: User, spinning module GCodes, available RAM 12428 bytes (slot 1)<LF>Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN<LF>Error status: 0<LF>MCU temperature: min 27.2, current 31.2, max 31.4<LF>Supply voltage: min 0.4, current 1.6, max 1.6, under voltage events: 0, over voltage events: 0, power good: no<LF>Driver 0: ok, SG min/max not available<LF>Driver 1: ok, SG min/max not available<LF>Driver 2: ok, SG min/max not available<LF>Driver 3: o[Warning: Maximal number of bytes per line exceeded! Check the EOL (end-of-line) settings or increase the limit in the advanced terminal settings.]
  • @Sqwuid
    it seems to have updated the firmware. are you connecting via usb serial?
  • I am now, for some reason the wifi module stopped working during the install. I am attempting to get it to reconnect.
    I've gotten the wifi module to idle, but after giving it the m587 command with my ssid and password it simply says "OK", and doesn't do anything. I can't access the web control.
  • Moderator
    If you send m552 does it say it has an ip?
    You may need to reflash to module. Send m997 S1.
  • Got it squared away, had to take out sd card and all that. Alright, we are updated completely and I can now see my tools. Got some issues with the heater I guess and some warning messages.
    m98 P"Config.g"
    Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
    Current config
    ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sat Sep 05 2020 05:42:29 GMT-0500 (Central Daylight Time)
    M574 Z2 S2                                             ; configure Z-probe endstop for high end on Z
    M308 S0 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 0 as thermistor on pin e0temp
    M950 H0 C"e0heat" T0                                   ; create nozzle heater output on e0heat and map it to sensor 0
    M307 H0 B0 S1.00                                       ; disable bang-bang mode for heater  and set PWM limit
    M308 S1 P"bedtemp" Y"thermistor" T100000 B4138         ; configure sensor 1 as thermistor on pin bedtemp
    M950 H1 C"bedheat" T1                                  ; create bed heater output on bedheat and map it to sensor 1
    M307 H1 B1 S1.00                                       ; enable bang-bang mode for the bed heater and set PWM limit
    M140 H1                                                ; map heated bed to heater 1
    M143 H1 S120                                           ; set temperature limit for heater 1 to 120C
  • @Sqwuid said in Updated to V3, now nothing works!:
    that can be ignored.
  • Moderator
    Glad you got it sorted out!
    The warning is just a warning. Understand it and take precautions. Then you can ignore it.
    https://duet3d.dozuki.com/Wiki/FAQ#Section_M307_Heater_1_appears_to_be_over_powered_If_left_on_at_full_power_its_temperature_is_predicted_to_reach_521C
  • Ok! Thanks so much for your help so far. We're redoing the config file now because all of our troubleshooting got it all mixed up!
    We had a question about the i/o mapping since we have the bl touch. Will the endstop pin just be zstop?
    When we do that, the M574 command for Z disappears from config and the only thing left is Z-Probe stuff.
  • Moderator
    Depends if you want to use a Z endstop and the z probe at the same time. It may be easiest to just add back the endstop definition afterwards.
    That way the cnfigurator will set thing sup for the probe to use it for homing.
  • We don't technically have a z endstop, just the probe. Not sure if that counts.
    We've run through a bunch of stuff, updated, edited, auto-tuned (cause that's a thing now, that's cool 🙂 ), but we're running into bl touch deploying issues. Shocking, one more bl touch question.
    Probe tests itself upon startup. M280 commands are not working, however.
    Below is our current config.g.
    M308 S0 P"bedtemp" Y"thermistor" T100000 B4138         ; configure sensor 0 as thermistor on pin bedtemp
    M950 H0 C"bedheat" T0                                  ; create bed heater output on bedheat and map it to sensor 0
    M307 H0 A129.6 C719.5 D0.9 V24.2 B0                    ; autotune for PID bedheat
    M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
    M950 H1 C"e0heat" T1                                   ; create nozzle heater output on e0heat and map it to sensor 1
  • Moderator
    What do you have in your deploy and retract macros?
    What M280 commands are you trying to send?
    If you don't have a Z endstop, then you've got nothing to worry about.
    post your homing files as well if you want those checked over.
  • You're a dream, thank you!
    M280 P0 S10 ; deploy BLTouch
    M280 P0 S90 ; retract BLTouch
    We just tried using M401/M402 and it didn't respond either.
    ; homeall.g
    ;G91                    ; relative positioning
    ;G1 Z5 F100             ; lift Z relative to current position
    ;G90                    ; absolute positioning
    ; homex.g
    ; called to home the X axis
    G1 H1 X-725 F1800 ; move quickly to X axis endstop and stop there (first pass)
    G1 H2 X5 F6000    ; go back a few mm
    G1 H1 X-7255 F360  ; move slowly to X axis endstop once more (second pass)
    G1 H2 Z-5 F6000   ; lower Z again
    ; homey.g
    ; called to home the Y axis
    G1 H1 Y-355 F1800 ; move quickly to Y axis endstop and stop there (first pass)
    G1 H2 Y5 F6000    ; go back a few mm
    G1 H1 Y-355 F360  ; move slowly to Y axis endstop once more (second pass)
    ; homez.g
    ; called to home the Z axis
    G1 X350 Y150 F6000 ; go to first probe point
  • Moderator
    And you're sure you're using heater pin 7?
    Did any wiring change?
    Was it working in rrf2?
  • EDIT: We are stupid. I just counted the pins again. My husband is blind. I am blaming him for this one!
    It's deploying now. Love you guys, thanks so much!
    ~~Pretty sure, according to the diagram.
    I used to have it on heater3 with v2 and it worked fine. When it stopped working after trying to update, we went back to basics and followed the tutorial to the letter. That included moving it to heater7.
    We changed that in the config, however. We're just not sure if any of it is right now because of the update.~~
  • Moderator
    I'm on mobile so it's harder to see but I don't think you're on the right pin.
