    Magnetic filament monitor case with switch integrated ?
    Filament Monitor
    1
    1
    98
    • BoAundefined
      BoA
      Is there any STL for magnetic filament monitor case with transoptor/switch integrated?
      I would like to have monitor to react immediately for end of filament instead of waiting for no filament movement report.
      I have reversed bowden setup, and extruder is basically not able to push pack enough filament so it can not be removed without disconnecting tubes.
      I would imagine, that sensing position of sensor idler (this element on spring) is easy task, but I could not find any sensor casing that has this implemented.
