Upload firmware?
  • When I run M997 S0, it says something like "please wait while firmware is being updated" - Then after a while is says "operation has been canceled" - No explanation.
    What to do?
    9/6/2020, 7:58:59 PM M122
    RepRapFirmware for Duet 3 v0.6 version 3.0alpha running on Duet 3 version v0.6
    Board ID: 08DGM-9T66A-G63SJ-6J9FJ-3SD6R-KS0ZA
    Used output buffers: 2 of 32 (8 max)
    Static ram: 67772
    Dynamic ram: 156016 of which 0 recycled
    Exception stack ram used: 612
    Never used ram: 168816
    Tasks: NETWORK(ready,456) HEAT(blocked,1208) CanReceiv(suspended,3804) CanSender(suspended,1496) CanClock(blocked,1432) TMC(blocked,592) MAIN(running,3472) IDLE(ready,156)
    Owned mutexes:
    Last reset 00:02:44 ago, cause: reset button
    Last software reset time unknown, reason: User, spinning module GCodes, available RAM 168424 bytes (slot 1)
    Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x04429000 BFAR 0x00000000 SP 0xffffffff Task 0x4e49414d
    Error status: 0
    Free file entries: 10
    SD card 0 detected, interface speed: 25.0MBytes/sec
    MCU temperature: min 42.7, current 43.2, max 44.1
    Supply voltage: min 20.0, current 20.1, max 20.2, under voltage events: 0, over voltage events: 0, power good: yes
    12V rail voltage: min 12.0, current 12.1, max 12.2, under voltage events: 0
    Driver 0: standstill, reads 4336, writes 14 timeouts 0, SG min/max 0/0
    Driver 1: standstill, reads 4338, writes 14 timeouts 0, SG min/max 0/0
    Driver 2: standstill, reads 4339, writes 14 timeouts 0, SG min/max 0/0
    Driver 3: standstill, reads 4341, writes 14 timeouts 0, SG min/max 0/0
    Driver 4: standstill, reads 4345, writes 11 timeouts 0, SG min/max 0/0
    Driver 5: standstill, reads 4347, writes 11 timeouts 0, SG min/max 0/0
    Slowest loop: 1.55ms; fastest: 0.29ms
    Hiccups: 0, FreeDm: 375, MinFreeDm: 375, MaxWait: 0ms
    === MainDDARing ===
    Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
    === AuxDDARing ===
    Heater 1 is on, I-accum = 0.0
    Segments left: 0
    Movement lock held by null
    http is idle in state(s) 0
    telnet is idle in state(s) 0
    file is idle in state(s) 0
    serial is idle in state(s) 0
    aux is idle in state(s) 0
    daemon is idle in state(s) 0
    queue is idle in state(s) 0
    lcd is idle in state(s) 0
    spi is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 25.26ms; fastest: 0.03ms
    Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
    HTTP sessions: 1 of 8
    • Ethernet -
      State: 5
      Socket states: 5 2 2 2 2 0 0 0
      === Linux interface ===
      State: 0, failed transfers: 0
      Last transfer: 164619ms ago
      RX/TX seq numbers: 0/1
      SPI underruns 0, overruns 0
      Number of disconnects: 0
      Buffer RX/TX: 0/0-0
      9/6/2020, 7:56:19 PM M997 S0
      Operation has been cancelled
      9/6/2020, 7:55:36 PM Connected to 192.168.1.229
  • to which firmware version are you upgrading?
    3.0 and then 3.1.1 as described in the readme?
  • Nope 🙂
    Trying 3.0 now. It pretty fast lost connection to the interface, and now I can't connect to it. How long is this supposed to take? - Looks like it's just gone. How long should I wait before I power cycle it?
  • Fark.... Powercycling did nothing, it is unreachable 😞
    Now what?
  • see
    https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3
    To update via USB (using a Windows host):
  • That worked. Thanks.
