PanelDue stuck on "Connecting" after Duet Wifi Firmware Update
  • I've updated my Duet Wifi firmware first to 3, which worked fine. The Duet Wifi rebooted, the PanelDue showed the new version. Then I updated to 3.1.1. This time, the PanelDue remained stuck on the "Rebooting" message after the update. When I manually reset the machine, the PanelDue is stuck in the "Connecting..." state.
    The Duet Wifi itself seems to work okay, I can connect to it from Pronterface.
    Any ideas?
  • whats the firmware version of the paneldue?
    can you manually send M575 P1 S1 B57600 and see if it connects
    Do you have the correct M575 command in config.g? This command used to be optional, but in 3.1.x it is required when using a PanelDue.
  • did you add the config to enable PanelDue serial port as of 3.1.0 as pr https://github.com/Duet3D/RepRapFirmware/blob/v3-dev/WHATS_NEW_RRF3.md#reprapfirmware-310 ?
    All PanelDue users: the PanelDue connector (or IO_0 on Duet 3) is no longer dedicated to PanelDue, therefore if you connect a PanelDue to this port you must use the following command in config.g to enable it: M575 P1 S1 B57600. You can use baud rates other than 57600, however the IAP files all assume 57600 baud; therefore if you use another baud rate then PanelDue will not display firmware update progress.
  • The M575 command fixed it! Thank you so much!
