    Pause on motor disconnect
    Firmware wishlist
    • Nxt-1
      Nxt-1 last edited by
      While printing overnight one of the wires to my extruder motor broke just above the crimp. Checking the console tab on the PanelDue, there were numerous warnings about the "motor phase may be disconnected". This is all fine and dandy, but I wonder why there is no pause triggered on such a warning, as it is quite serious and I have never seen a false positive.
      Therefore my feature request, trigger a pause on a detection of a motor phase disconnected. Or at least make it configurable via g-codes
      Duet3D and delta printer enthousiast. Buildlog
      Looking for Duet3D configuration support, check out Nxt-3D
        Unfortunately the "disconnected" warnings are often spurious. They can be triggered just by setting low motor currents (so we suppress the warnings below 500mA now) and by other conditions. Trinamic advises that they are intended for debugging only. But in some cases they are reliable, so i guess we could consider an option to pause the print.
        Nxt-1 1 Reply Last reply Reply Quote 0
        • A Former User
          A Former User last edited by
          would the duet be able to use something like the super cheap printed filament sensor @ fractalengineer designed as a poor mans closed loop system for motion?
          i.e just pause if something that is a significant deviation occurs - or is it just too much work for the duet/dev?
          • Nxt-1
            Nxt-1 @dc42 last edited by
            @dc42 I didn't know this feature was considered for debugging only. I guess the drivers are using some indirect type of measurement and not some plain resistance measurement.
            I guess making it configurable and documenting it well to informing that it might trigger false positives, especially at low currents.
