    Need Probe Setup Help
    Firmware installation
    1.3k
    • 1d1undefined
      1d1
      I have a switch type probe that I am trying to set up. Totally confused about the nomenclature. So, here is M115:FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-05-19b2
      Current probe settings with the switch installed on E0 and the probe registering when pushed with board LED on/then going off:
      M558 P8 C"!io0.in" H5 F300 T6000 R0.4           ; set Z probe type to switch and the dive height + speeds
      G31 P500 X0 Y0 Z20.6                            ; set Z probe trigger value, offset and trigger height
      M557 R52 S20                                   ; define mesh grid
      Once this is correct, I can move on to 2 other issues to complete my installation. It's been a tough slog so far.
        jay_s_uk
        If it is a simple switch, you should be using P5.
        What issues are you having?
        • 1d1undefined
          1d1
          I was using P8 for an unfiltered response. When I employ the probe command, it stops above the bed and probes the air.
            jay_s_uk
            is it a delta? Try running G30 first to get the correct bed height
            • 1d1undefined
              1d1
              Yes, delta. G30, then M558?
                jay_s_uk
                No, making sure you have M501 at the end of your config, send the following commands
                G30
                G32
                M500
                • 1d1undefined
                  1d1
                  OK. G30 gives me 2 error messages: G30
                  Error: G30: Z probe 0 not found
                  9/17/2020, 10:20:06 AM	G30
                  Error: G30: Insufficient axes homed for bed probing
                    jay_s_uk
                    Post your whole config as you seem to have an issue with your M558 setting
                    • 1d1undefined
                      1d1
                      Q5
                      G30
                      Status
                      Idle
                      Mode: FFF
                      Tool Position
                      X
                      0.0
                      Y
                      0.0
                      Z
                      205.01
                      Extruder Drives
                      Drive 0
                      0.0
                      Speeds
                      Requested Speed
                      0 mm/s
                      Top Speed
                      0 mm/s
                      Sensors
                      Vin
                      24.2 V
                      MCU Temperature
                      33.2 C
                       Tools
                       Extra
                       Control All
                      Tool	Heater	Current	Active	Standby
                      Tool 0
                      T0 - Load Filament	Heater 1
                      off	20.3 C
                      0
                      0
                      Bed	Heater 0
                      off	21.0 C
                      0
                      0
                      Temperature Chart
                      System Directory
                      0:/sys/config.g
                      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Sep 16 2020 09:55:19 GMT-0400 (Eastern Daylight Time)
                      G90                                            ; send absolute coordinates...
                      M83                                            ; ...but relative extruder moves
                      M550 P"Q5"                                     ; set printer name
                      M665 R104.3 L215 B180.8 H210                   ; Set delta radius, diagonal rod length, printable radius and homed height
                      M666 X0 Y0 Z0                                  ; put your endstop adjustments here, or let auto calibration find them
                      M552 S1                                        ; enable network
                      M586 P0 S1                                     ; enable HTTP
                      M586 P1 S0                                     ; disable FTP
                      M586 P2 S0                                     ; disable Telnet
                      M569 P0 S1                                     ; physical drive 0 goes forwards
                      M569 P1 S1                                     ; physical drive 1 goes backwards
                      M569 P2 S1                                     ; physical drive 2 goes forwards
                      M569 P3 S1                                     ; physical drive 3 goes forwards
                      M584 X0 Y1 Z4 E3                               ; set drive mapping
                      M350 X16 Y16 Z16 E16 I1                        ; configure microstepping with interpolation
                      M92 X80.00 Y80.00 Z80.00 E663.00               ; set steps per mm
                      M566 X1200.00 Y1200.00 Z1200.00 E1200.00       ; set maximum instantaneous speed changes (mm/min)
                      M203 X18000.00 Y18000.00 Z18000.00 E1200.00    ; set maximum speeds (mm/min)
                      M201 X1000.00 Y1000.00 Z1000.00 E1000.00       ; set accelerations (mm/s^2)
                      M906 X800 Y800 Z800 E600 I30                   ; set motor currents (mA) and motor idle factor in per cent
                      M84 S30                                        ; Set idle timeout
                      M208 Z0 S1                                     ; set minimum Z
                      M574 X2 S1 P"xstop"                            ; configure active-high endstop for high end on X via pin xstop
                      M574 Y2 S1 P"ystop"                            ; configure active-high endstop for high end on Y via pin ystop
                      M574 Z2 S1 P"zstop"                            ; configure active-high endstop for high end on Z via pin zstop
                      M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
                      M307 H0 B1 S1.00                               ; enable bang-bang mode for the bed heater and set PWM limit
                      M140 H0                                        ; map heated bed to heater 0
                      M143 H0 S100                                   ; set temperature limit for heater 0 to 100C
                      M308 S1 P"e0temp" Y"thermistor" T100000 B4138  ; configure sensor 1 as thermistor on pin e0temp
                      M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
                      M307 H1 B0 S1.00                               ; disable bang-bang mode for heater  and set PWM limit
                      M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
                      M106 P0 S1 H T45                               ; set fan 0 value. Thermostatic control is turned on
                      M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
                      M106 P1 S1 H1 T45                              ; set fan 1 value. Thermostatic control is turned on
                      M950 F2 C"fan2" Q500                           ; create fan 2 on pin fan2 and set its frequency
                      M106 P2 S1 H1 T45                              ; set fan 2 value. Thermostatic control is turned on
                      M563 P0 D0 H1 F0                               ; define tool 0
                      G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
                      G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
                      M501
                        jay_s_uk
                        remove lines 1 to 42 from your config file. they shouldn't be there
                        • 1d1undefined
                          1d1
                          Interesting. Those lines do not show in my config.g. I am copying the config.g by selecting all, copy, paste. When I do that those other lines appear but I don't see them otherwise. Weird.
                          M501
                            jay_s_uk
                            If you send M558, what does it output?
                            • 1d1undefined
                              1d1
                              M558
                              Error: M558: Z probe 0 not found
                                jay_s_uk
                                I've just realised why. You've used a duet 3 pin name with a duet 2.
                                Where do you have it connected?
                                • 1d1undefined
                                  1d1
                                  At position E0 on the endstop connectors
                                    jay_s_uk
                                    change your command to
                                    M558 P8 C"!e0stop" H5 F300 T6000 R0.4
                                    • 1d1undefined
                                      1d1
                                      @jay_s_uk said in Need Probe Setup Help:
                                      Done.
                                      • 1d1undefined
                                        1d1
                                        Before you ask:
                                        m558
                                        Z Probe 0: type 8, input pin !e0stop, output pin nil, dive height 5.0mm, probe speed 300mm/min, travel speed 6000mm/min, recovery time 0.44 sec, heaters normal, max taps 1, max diff 0.03
                                          jay_s_uk
                                          Run G30 and see if it probes.
                                          I would make sure you've homed your machine using G28 and then tap the probe on the way down to make sure it stops
                                          1d1undefined 1 Reply Last reply Reply Quote 0
                                          • 1d1undefined
                                            1d1 @jay_s_uk
                                            @jay_s_uk
                                            "Probe already triggered"
                                            Remove exclamation point from 558?
