    Duet 2 wifi system editor file list infinaite
    Duet Web Control
    411
    • Andrewechongundefined
      Andrewechong
      I attempted to figure this out on my own but I had no success. I reformatted my SDcard using the suggested method using link text and have also done so on another SDcard just to see if that one was bad.
      I am able to upload the firmware using the provided SD card and I am able to set up internet access through YAT. When I use the provided IP address provided by the duet 2 I am able to open up the online interface but when I try to do anything it says there not file found - for example Ill try to home Y and it will say homing gcode not found" or something of the sort. And when I try to edit the files in the system editor, it multiplies the list of found files infinitely. I am able to open the file if I click on it but the machine does not seem to recognize it.
      I chose not to buy the LCD screen that comes with it. I planned on only using the wifi feature.
      • Vetiundefined
        Veti
        @Andrewechong said in Duet 2 wifi system editor file list infinaite:
        home Y
        you have a delta configuration. you can not home y. on a delta you can only home all
          I suspect that the versions of RepRapFirmware and DuetWebControl that you are using are from different releases and incompatible.
            Andrewechong
            This is just an example firmware I found off github link text
            I uploaded my own config files I got off of "configtool.reprapfirmware.org" and I am still getting the infinite system editor"
              That's very old firmware. I suggest you upgrade initially to RepRapFirmware 2.05.1 here https://github.com/Duet3D/RepRapFirmware/releases/tag/2.05.1.
                Andrewechong
                ![0_1600526932402_duet 2 wifi zip file from config tool .jpg](Uploading 100%)
                I used the Duet Web Control 3.1.1 and uploaded the latest release from that website and I am able to connect to the server through the provided IP but the problem still persists.
                ![0_1600527053855_combined firmware .jpg](Uploading 100%)
                Andrewechongundefined 1 Reply Last reply Reply Quote 0
                  Andrewechong
                  The photo will not upload. it says there's a parsing problem. But I did upload the Duet2CombinedFirmware.bin from the provided URL you gave me from the latest releases.
                    Andrewechong @Andrewechong
                    @Andrewechong @dc42
                      Andrewechong
                      • Vetiundefined
                        Veti
                        you seem to have managed to have a very inconsistent state.
                        please read
                        https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Usual_procedure
                        i think you need to start at
                        Fallback procedure #1
                        Andrewechongundefined 1 Reply Last reply Reply Quote 2
                          Andrewechong @Veti
                          @Veti Thank you so much! I went through the directions and everything works god now! I really appreciate it!
