I don't know what's wrong.
  • m552 s1
    ok
    WiFi reported error: no known networks found
    WiFi module is idle
    m587
    Remembered networks:
    test IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
    ok
    m122
    RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
    Board ID: 08DLM-996RU-N85S4-7JTD8-3S46R-9VBVP
    Used output buffers: 1 of 24 (11 max)
    Static ram: 27980
    Dynamic ram: 93236 of which 20 recycled
    Exception stack ram used: 256
    Never used ram: 9580
    Tasks: NETWORK(ready,844) HEAT(blocked,1456) MAIN(running,1720) IDLE(ready,80)
    Owned mutexes:
    Last reset 00:05:11 ago, cause: software
    Last software reset time unknown, reason: Watchdog timeout, spinning module GCodes, available RAM 11680 bytes (slot 2)
    Software reset code 0x00a3 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0043380f BFAR 0xe000ed38 SP 0x200049d4 Task MAIN
    Stack: 004486cf 0042a316 21000000 3f800000 00000000 00000000 00000000 3331bb4c 40000000 3f317200 b5ddea0e
    Error status: 0
    MCU temperature: min 35.3, current 35.6, max 35.9
    Supply voltage: min 1.7, current 1.7, max 1.8, under voltage events: 0, over voltage events: 0, power good: no
    Driver 0: ok, SG min/max not available
    Driver 1: ok, SG min/max not available
    Driver 2: ok, SG min/max not available
    Driver 3: ok, SG min/max not available
    Driver 4: ok, SG min/max not available
    Cache data hit count 611435937
    Slowest loop: 99.89ms; fastest: 0.09ms
    === Storage ===
    Free file entries: 10
    SD card longest read time 3.1ms, write time 0.0ms, max retries 0
    Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
    === MainDDARing ===
    Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
    === AuxDDARing ===
    Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
    Segments left: 0
    Movement lock held by null
    HTTP is idle in state(s) 0
    Telnet is idle in state(s) 0
    File is idle in state(s) 0
    USB is ready with "m122" in state(s) 0
    Aux is idle in state(s) 0
    Trigger is idle in state(s) 0
    Queue is idle in state(s) 0
    Daemon is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 1.31ms; fastest: 0.00ms
    HTTP sessions: 0 of 8
    • WiFi -
      Network state is active
      WiFi module is idle
      WiFi firmware version 1.23
      WiFi MAC address ec:fa:bc:5b:45:b7
      WiFi Vcc 3.36, reset reason Unknown
      WiFi flash size 4194304, free heap 30176
      ok
    what's wrong...
    Please use your other thread to continue this discussion.
