BLTouch Duex5
  • Bonsoir après avoir passer toute la journée a essayer de faire fonctionner mon BLTouch https://betrue3d.dk/bltouch-on-duet-wifi-configuratio-and-usage/#configuring en suivant se lien sans succès je demande votre aide.
    Lorsque j'allume ma machine mon BLTouch se déploie correctement en fessant les Macro test (M280 P7 S120) marche aussi mais en demandant un HOME Z la le deplacement se fait correctement mais la pine se déploie pas.
  • Moderator
    Post your config.g and homeall.g
    The homeall,g must contain a G30 to call the probe.
    The deployprobe.g and retractprobe.g macros must contain the corresponding M280 servo command. Test with M401 and M402 to deploy and retract.
  • Config.g
    ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sat Oct 03 2020 15:26:33 GMT+0200 (heure d’été d’Europe centrale)
    M550 P"MonsterPrinter" ; set printer name
    M552 S1 ; enable network
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    M569 P1 S0 ; physical drive 1 goes forwards
    M569 P2 S0 ; physical drive 2 goes forwards
    M569 P5 S1 ; physical drive 5 goes forwards
    M569 P6 S1 ; physical drive 6 goes forwards
    M569 P7 S0 ; physical drive 7 goes forwards
    M584 X0:5 Y1:6 Z2:7 E3 ; set drive mapping
    M92 X100.00 Y80.00 Z400.00 E420.00 ; set steps per mm
    M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X9000.00 Y9000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
    M906 X800 Y1000 Z1390 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X-6 Y-10 Z0 S1 ; set axis minima
    M208 X780 Y510 Z350 S0 ; set axis maxima
    M574 Y2 S0 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
    M574 Z1 S2 ; Define Z to use Probe. Home to Min
    M558 P9 H10 F500 T4000 X0 Y0 Z1 ; Set Z probe type/mode 5. H=Dive Height. F=Speed the bed moves
    G31 P100 X0 Y-20 Z6.46 ; set Z probe trigger value, offset and trigger height
    M557 X20:760 Y20:480 S80 ; define mesh grid
    M307 H7 A-1 C-1 D-1 ; Disable the 7th Heater to free up PWM channel 5 on the Duex board.
    M143 H0 S150 ; set temperature limit for heater 0 to 150C
    M305 P1 T4606017 B5848 C5.548428e-8 R4700 H0 L0
    M308 S1 P"e0temp" Y"thermistor" T4606017 B5848 ; configure sensor 1 as thermistor on pin e0temp
    M307 H1 A580.4 C256.6 D6.4 S0.50 ; disable bang-bang mode for heater and set PWM limit
    M143 H1 S493
    Homeall.g
    ; homeall.g
    ; called to home all axes
    G91 ; relative positioning
    G1 H1 X-787 Y505 F3600 ; move quickly to X and Y axis endstops and stop there (first pass)
    G1 H2 X5 Y-5 F6000 ; go back a few mm
    G1 H1 X-787 Y505 F600 ; move slowly to X and Y axis endstops once more (second pass)
    G1 H1 Z-405 F600 ; move Z down stopping at the endstop
    G90 ; absolute positioning
    G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
    ;G91 ; relative positioning
    ;G1 Z5 F100 ; lift Z relative to current position
    ;G90 ; absolute positioning
  • M401 and M402 it’s working normaly
  • I think my Homez.g file is not good either
  • @chris974M
    as Phaedrux said, zou are missing a G30 in your home script.
    i would suggest that you use you config.json to reupload you config to the configurator and enable bltouch there. it will generate all thins correctly for you.
  • Ok si je fait sa est ce que je perd mes autre confît.g ( XYZ dual axis ) ?
  • Moderator
    You can just compare what is different and take just the zprobe section and copy and paste it into your config.
  • ok i try
  • C'est ok merci
